Thread: Pool Finishes-Need Help!
    Jun 2016
    dallas, tx
    17
    We need to decide on our pool finish soon and I thought I was going with Pebble Sheen, but now after checking out some pools (it's the most common pool finish around here), I am wanting to at least check into some smoother finishes. Here are the options we are considering:
    Pebble Fina--I have never seen this IRL so don't know anything about it
    Quartz finish--I am highly interested in this but keep hearing that it might be mottled and not turn out well
    Pebble Sheen--this is still on the list because it is gorgeous and I'm thinking maybe the roughness would be something you would get used to
    This is not a play pool, so the pool roughness might not matter quite as much as it would in a play pool.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool Finishes-Need Help!
    Welcome to TFP
    I did some searches and found this
    https://www.google.com/search?sitese...y=5&gws_rd=ssl
    Google
    Google
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    There are lots of discussions here on this subject.
    Here is on that is active right now,
    Considering Pebble Tec but have concerns
    Jun 2016
    dallas, tx
    17
    Thanks for the replies. I've read most of the threads linked. I'm still undecided, so I guess really it just comes down to personal preference. I've even gone to pools with the different finishes, and am still undecided!
