Results 1 to 9 of 9
Thread: Ammonia Test Kit
    patrick3229's Avatar
    Feb 2012
    258
    Ammonia Test Kit
    We have a customer that thinks they may have ammonia in their pool water due to spraying of crops near by. This is what their pool store has told them, but we want to make sure this is accurate, can anyone suggest a test kit for testing for ammonia in pool water?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Ammonia Test Kit
    A pet store should have aquarium ammonia test kit strips
    I am using my phone so please excuse any spelling errors and short response.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Search Results
    Here are some from Pet Smart.
    Let us know if they do not have access to a pet store and we have another way to "test" if they have it.
    Kim
    Feb 2012
    258
    cowboycasey and kimkats thanks so much!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Now that the answer is out of the way are those your donkeys in the avatar?
    Here's mine
    Attachment 35555
    Jul 2015
    Central Valley CA
    1,108
    Do they like waffles? .
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2012
    258
    PoolDV Yes those are donkeys in my avatar we have two mini's they are awesome and do a great job mowing the yard I tried to view your attachment but it would come up for me, I would love to see them!
    DFW, TX
    24,497
    Quote Originally Posted by atttech-2 View Post
    LOL! Prolly!
    Quote Originally Posted by patrick3229 View Post
    Dang that attachment! Nice! We've got 4 yard mowing, heehawing pasture ornaments. We were up to 8! Had to separate the boys from the girls!
    May 2016
    Amarillo, Texas
    38
    Quote Originally Posted by kimkats View Post
    Search Results
    Kim
    Spray from crops sounds pretty far fetched, but there are a lot of other ways to get ammonia.
    This is a key test for aquariums, so any place with fish or pet products should have it. I have a kit with the drops. I don't know how well the strips work, but I would look at the scale on any of the tests. I think I had a good low end, but then it jumped like 0.5, 1.0, 2.0, 4.0, 8.0... So if you get one of the higher readings, be prepared for a lot of chlorine just to be able to get a reading.
    I just went through this and a good rule of thumb is to multiply your NH3 reading by about 12 and that should give you about how much FC on the calculator you will need before you can start raising FC. So a reading of 2 is approximately 24 FC worth of bleach. I was adding and testing and it came down pretty close to this amount each time.
