Thread: Need help with intex manual!
    Intex manual
    Can someone please help me identify what numbers 26,27,28 replacement parts ID numbers would be? missing from the manual? Errrr
    Thanks in Advance!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Need help with intex manual!
    26 is the o-ring for the bottom of the plunger valve. 28 is the step washer. If you scroll down further it shows the same plunger valve diagram with the filter information. They are number 22 and 23 in that image. 27 is the "nut" for attaching the plunger valve to the pool wall fitting. It is not designed to come off, so if that part is missing you will need to replace the plunger valve.
    Love TFP? Become a
    TFP Supporter!
