Thread: Filter Pressure compared to Pump Size
    May 2015
    kingston springs, tn
    102
    Hello - My pool has hovered around the same filter pressure of 10-12 PSI since install 10 years ago. My pump is a 1 Hp and is located 10 feet from the outside edge about 4' above the water level. Pool is 18x36 with 1.5" PVC Piping. Obviously the pressure hasn't been a big issue considering it has worked fine and still does. My question is would it be a bad thing to go to a 1.5 Hp variable speed or two speed pump? Are there any drawbacks to increasing the pump motor size other than 1.5 hp uses more power. Opinions and advice are appreciated.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    38,248
    Re: Filter Pressure compared to Pump Size
    A bigger pump would cost more and use more power.
    Why do you think you need more flow?
    Consider just putting a 1HP 2 speed on your existing pump. Then no plumbing and you can run on low to save $ on power.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If your filter pressure never rises, that must mean you do a good job of maintaining chemistry and have limited problems with dust or pollen or other debris in your pool. Or your gauge is broken. Do you ever backwash? If so, when?
    With your size filter, you could likely handle the extra 0.5 HP without flow going to fast through the filter. Filtration is better when it's not too fast and being way to fast can lead to channeling of the filter, which would decrease it's ability to filter. Is there a reason you're looking to upsize the filter? Better circulation? Eliminate your booster pump?
    If you do go to a larger size pump, consider a 2 speed or variable speed pump to increase your flexibility with flow and reduce electricity costs, especially with a SWG system that may necessitate longer runtimes for proper chlorination.
    Isolated Spa - 345 Gallons
    May 2015
    102
    I backwash about once to twice a month depending on if it needs it. Usually after a 3 - 4 psi rise in pressure. The only swimmers are myself and my wife. I work from my home office so keeping it clean is a phobia of mine during the summer months. The filter is a TR-60 and I replaced the gauge a couple of weeks ago when I replaced the pressure relief valve and the spider gasket. The filter I have is fairly large and it holds "I think" 350 pounds of sand which I replaced last year with new laterals. My equipment is located in an enclosed area that does not get exposed to the elements. If the lower the pressure is better that is what I wanted to know. I have just read so many threads with higher pressure than mine and it made me start thinking would a higher flow make a positive difference.
    Feb 2014
    Central Minnesota
    5,080
    I have a similar sized filter to yours and my 1 HP pump. My clean pressure is 13 - 14 ppm. Lower pressure when clean is definitely a good thing. I'd only be worried if you were in the mid single digits.
    May 2015
    102
    It is never that low... 10 is the lowest I've seen it when clean. Thank you everyone for the feedback.
