Thread: Add lights to inground pool
    Hi guys,
    Just purchased a new home with in ground pool. The previous owners had the liner replaced two years ago and apparently had an issue with the existing light, it was a niche light under the diving board lighting up the pool with a 500w bulb. Instead of fixing it, they just decided to condemn it and have the liner cover it...! Now I have a beautiful 15 x 32 pool with no lights...! what are my options and what am I looking at in terms of cost to have one put back in place. Apparently the wiring is still there.
    Thanks!
    10,000 gallons IG Freeform, 8ft raised spa,pebble finish
    FNS 60 Sqft DE Filter,2HP Whisperflow for Pool/Spa filtering
    2HP Whisperflow for Spa jets
    1HP Whisperflow for Waterfall
    Master Temp 400,000 Btu Heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Add lights to inground pool
    they cut holes in liners all the time and install lights, how hard and if you can DIY it I am unsure... see how much a company will do it for you and ask if its ok if you buy the light..
