Results 1 to 13 of 13
Thread: Skimmer or auto feeder
    May 2009
    southampton England
    6
    Hi quite new to pools so still learning. Weather is **** in the uk so i have fitted a low profile hard cover.i use Di clor Tabs in a pentair 320 but i think it uses too many tabs as they all dissolve quite quickly. The cover keeps out all the unwanted stuff so the pool is very clean, should i go back to putting tabs in the skimmer :
    Peter
    16x32 IG 20 " sand filter
    Raypac gas heater
    1hp certkin pump
    Abrisud telescopic hard swim under cover
    Casey's Avatar
    SW PA
    10,448
    Re: Skimmer or auto feeder
    Can you please post a full set of numbers?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by peter
    Peter
    Welcome to TFP!
    You should not put tabs in the skimmer. I think I read that Dichlor tabs dissolve faster than trichlor, do you have access to trichlor tabs? Does your chlorinator have a dial that can be adjusted down?
    Are you having water clarity issues? If so, like Casey said, post a full set of test results.
    To answer your q, no you should never put tabs in the skimmer, tablets are acidic and lower pH, this can be harmful to the skimmer parts causing them to become brittle and break easily, and it can wreak havoc on pump/filter/heater parts. Keep them in the chlorinator or in a floater, never the skimmer.
    You can put your pool info/specs in your signature line, go to User Control Panel, then Profile, then Edit Signature.
    May 2009
    southampton England
    6
    Peter
    Water is crystal clear
    FC 5ppm
    Ph 7.2 constant
    TA 80
    Stabiliser 100
    Auto feeder dial is set to 1. Maybe i should only put two tabs in a week as that was all i put in the skimmer
    Ps still raining and windy
    Raypac gas heater
    1hp certkin pump
    Your CYA/stabilizer level is too high. I recommend lowering your CYA level down to between 30 and 50. The only practical way to do that is to replace water.
    You might want to think about switching to liquid chlorine/bleach. That does mean more carrying, but gives you much better control over your pool.
    May 2009
    southampton England
    6
    Peter
    Thanks ill look into changing my chemicals. Having a hard cover on means for most part of the time the pool acts like an indoor pool and has little burn off and no rain water getting in .Also it is not used often and only by my 3 children
    Raypac gas heater
    1hp certkin pump
    Nod's Avatar
    Jun 2008
    Nashville, NC
    69
    Yeah, your CYA is too high, which means you are going to burn through more pucks to keep your FC at performing levels. I would only use pucks when going on vacation. Otherwise you should switch to unstabalized chlorine or in your case, a SWG would be perfect since you don't want to fool with it much.
    Nod
    16x32 IG, polymer panel Vinyl Pool w/approx 21k gallons of H20
    1 HP Hayward Pump & 300lb Sand Filter ~ Polaris 280 Pool cleaner
    ~~Nashville, NC~~
    11,969
    Dichlor and Trichlor pucks both add CYA and your level is too high. So you need routine water replacement when using pucks to prevent that from happening. Your ph is also on the low end, caused by the pucks. You may want to increase that a bit to 7.4-7.6 and keep the TA at 100-120 if using pucks.
    I would drain some of your water out, about a foot at a time to lower the CYA level, in the meantime use liquid chlorine, and consider it for your everyday needs, and save the tablets for vacations.
    Feb 2008
    Denton, TX
    5,061
    Seems like I can recall a thread in the past where the poster, also from England, mentioned that you couldn't buy bleach or liquid chlorine over there as it was considered a hazardous material and required special permitting. Is this the case or am I dreaming this up?
    11,969
    Quote Originally Posted by 257WbyMag
    I vaguely remember that too, but I think that user found it, it was just called something slightly different?
    May 2009
    southampton England
    6
    Quote Originally Posted by Nod
    Glad i looked up what an SWG is. I nearly went to the pool shop and asked for a big can of it
    Raypac gas heater
    1hp certkin pump
    11,969
    Yeah, we throw words around on here, taking for granted that Noobs know what they mean.
    Nod's Avatar
    Jun 2008
    Nashville, NC
    69
    Sorry about that!
    Nod
    ~~Nashville, NC~~
