Results 1 to 9 of 9
Thread: Cloudy Water - 0 CYA
    May 2009
    Glenwood, Maryland
    67
    All,
    Thanks in advance for your help in getting my cloudy pool water cleared up.
    My pool is cloudy with a light green tint to it.
    Here are my results using the T-100 kit.
    CH - 5+ (Not sure how to measure higher as the scale only goes to 5)
    pH - 6.8 - 7.2
    FC - 2 ppm
    CC - 1 ppm
    TC - 3 ppm
    CH - 275 - 300
    TA - 70
    CYA - 0 (I did this test many times using several different kits. I can fill up the tube and still see the black dot clearly).
    I found a place that sells liquid bleach at 12%-15%.
    I dont want to dump it in if I should get my CYA up a bit.
    Thanks all for any recommendations on the steps to get my pool into seasonal shape.
    Thanks, Golfer
    35K Gal Gunite Pool, Starite Cartridge Filter (S8M150), Lochinvar 400K BTU Propane Heater, Pentair 3HP Intellipro VS + SVRS Pump, Hayward 3HP Pump (Waterfall), Dolphin M-500 Pool Cleaner, Well Water, TFT-100 Test Kit w/ Speed Stir
    38,548
    Re: Cloudy Water - 0 CYA
    I would do a quick check before adding CYA.
    Add 10ppm of FC with the pump running, wait 10-15 minutes, and retest the FC and CC.
    May 2009
    Glenwood, Maryland
    67
    How do I determine the amount to add to equal 10ppm? Thx
    Thanks, Golfer
    38,548
    You use PoolMath. See link in my Signature or at the top of the webpage.
    May 2009
    Glenwood, Maryland
    67
    I poured in 5 gallons of bleach and waited about an hour or so..
    Here is what I got..
    FC - 24
    CC - 2
    TC - 26
    CYA is not zero but can still see the dot when full. But a bit cloudy from earlier tests.
    Thx
    Thanks, Golfer
    38,548
    What was the strength of the bleach?
    Either it is crazy strong, your pool is much smaller than you think, or the test was not done correctly.
    Having the FC that high with near 0 CYA is not good.
    You did not add anything to change the CYA, so it should not be different.
    Add 30ppm of CYA in a sock suspended in front of a return jet.
    And follow the ShockLevelAndMAINTAIN Process
    May 2009
    Glenwood, Maryland
    67
    The liquid bleach is about 12-15%.
    I think my pool is that big.. 25x50, deep end 10', shallow end 3-4',, Free form.. Either that or the water guy took me for a ride when I had my pool filled in the past...
    Tests were done twice.. I most usually conduct each test twice when I am having issues. Just to be safe.
    Thx for the help.
    Thanks, Golfer
    38,548
    Well, how did you decide to add 5 gallons then? What were the settings in PoolMath that said you needed 5 gallons to get from a FC of 2ppm to 10ppm?
    May 2009
    Glenwood, Maryland
    67
    Your advice was to add 10ppm, not bring up to 10ppm. That is what I did.
    Not 100% sure of the exact % of the chlorine, I put 5 gallons in. Pool Math stated a bit more than 4 gallons.
    This am, the pool is still cloudy.
    FC - 17 (Dropped alot since last night)
    CC - 2
    TC - 19
    CYA - 0 (Stabilizer in sock all night. This am, sock was empty. I added more)
    Thanks for your help.
    Thanks, Golfer
