Results 1 to 9 of 9
Thread: Replacing top rails and Top support
    After uncovering pool I have bad rust problem on top rails and top support ring. Can these be changed out with the pool full if I only do 1 or 2 at a time?
    Jul 2014
    Oakbank, Canada
    389
    Re: Replacing top rails and Top support
    No. You are at risk that the pool will collapse and you are putting yourself or others in harms way doing so.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Apr 2013
    Sacramento, CA
    2,769
    I'm going to say it depends. You might be able to do it but after you pull one out you run the risk of not being able to get the replacement back in because the pool shifted. So i would recommend against it even if the pool has a design that would allow you to do this.
    so how much should I drain out to do this?
    Apr 2013
    Sacramento, CA
    2,769
    Because I don't know your pool I don't know. But 3/4 would be the minimum. That top cord is one of the most important engineering features of the pool. So if it has problems I would fix it. Depending on your pool design once the water starts climbing the sides of the pool it starts exerting considerable outward force so even a relatively small amount of water in the pool can affect the top rail or cord.
    It is a seaspray allure it is not even half full right now
    will that be low enough
    anybody know how full I can have pool to take off this support ring at top?
    Jul 2014
    Oakbank, Canada
    389
    Call the manufacture.
