Thread: Jacuzzi EW75 Filter Grids
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    Hi Everyone,
    I have an old Jacuzzi EW75 filter. I'm pretty sure that the grids need replacing because I am starting to see DE coming back from the returns after adding it to the skimmer. When I cleaned the filter last week, they were looking kinda old and beat up, so I think that is what's happening. Problem is that I think all the original equipment for this filter is discontinued.
    I have the straight grids now and have been seeing the curved ones that supposedly will fit this filter. Does anyone have this filter and can recommend replacement grids? The manifold looks okay, but if I have to replace the whole thing I will. I don't see any issues with the filter case itself (it's really just a shell around the grids right?), and if I can keep it with the plumbing in place, that would be great.
    Thanks for any insight or advice
    33K gal. Super Steel Grecian IG (built 1994), Vinyl Liner (Replaced 2013), Jacuzzi EW 75 DE Filter (Original 1994), 1 HP Heyward Super II Pump, TF-100 Test Kit, Polaris 380 Cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Jacuzzi EW75 Filter Grids
    Check with INYO Pools, hard to find stuff is is one of their specialties.
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    Quote Originally Posted by pooldv View Post
    Thanks. I ended up purchasing a complete new manifold with grids (curved style) from INYO. It seemed to be less expensive then replacing all of the grids. I also picked up a new O-Ring for the top. Hope this solves the problem.
    DFW, TX
    24,513
    Awesome, good luck!
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    The new style grids and manifold were a perfect fit.
    I just assumed that since my filter was old, the slight drip I saw off the back was something I had to live with. Well after replacing the O-ring, and greasing it up good, I saw no drip at all yesterday. Hopefully I can get another 10 years out of the dinosaur that I have for a filter!!
    Thanks again for the help.
