Results 1 to 12 of 12
Thread: what to do until test kit gets here?
    Jun 2016
    Bangor, Maine
    6
    I have a 15' (36" deep) Intex Easy Set pool that we just put up yesterday and filled. I've ordered the Taylor K-2006 test kit, but it won't be here for 5-9 days. Is there anything I can do now to try and prevent problems before the test kit arrives? I have a bottle of chlorine on hand but am nervous since I have no idea what amounts of chlorine a "healthy" pool would need. I'm flying blind in more ways than one!
    Thanks for the help,
    Brooke
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: what to do until test kit gets here?
    Hi Brooke,
    hopefully I can help get you started.
    I did a quick calculation of your 15 ft round x 3 ft deep pool and it holds 4000 gallons of water.
    How much of something to put in depends on how much water you have, and what chemical are in the water. Since its new, then there isnt much in there. So..
    1st go ahead right now and add 18 ozs of concentrated bleach. No facny splashless or scented stuff. Just plain ol bleach. Let your pump run at least 20 minutes after adding the bleach so it can be mixed well.
    Next, you need to go to walmart, home improvement, pool store, or anyplace pool products are sold. Buy come Stabilizer and Conditioner (we call it CYA). It is sold in 4 lb jugs. Buy one jug then come home. Pour 16 ozs of it into an old sock and tie the top of the sock closed so it cant come out. Then tie a string on the end of a pole and hang the sock in front of the return. Squeeze the sock occasionally to help the stabilizer excape the sock.
    The day after you added 12 ozs of stabilizer add 12 ozs of bleach only.
    Add 12 ozs every day until your test kit arrives. When your test kit arrives, test your water for all of the things to test for and tell us what the test results are. Then we can go from there.
    In the mean time, play around with pool math. Its what we use to calculate how much of something to add to the water.
    http://www.troublefreepool.com/calc.html
    Also while you are waiting, start with the ABCs of pool chemistry in Pool School. Then continue reading pool school articles about how to maintain your water levels, and what they should be.
    Divin Dave,
    Jun 2016
    Bangor, Maine
    6
    Thank you Dave for your help! There's so much more to this little pool than I realized! At what point would it be safe for my daughter to go swimming in the pool? Or should we just hold off until the test kit arrives and we make adjustments? I'll be purchasing the items suggested tomorrow and get right on it. Thank you again so much for taking the time to write that all out! Brooke
    38,371
    It is safe after you add 1-2ppm of FC and let that mix. After all, at this point it is the same as bath water
    You just want to be sure there is some FC in the water while swimming. The test kit will help tremendously once you get hands on.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Brooke,
    Above all, TFP wants everyone to be safe. We would never recommend someone to do anything that isnt safe unless we specifically tell them it isn't safe. But if you are unsure, please ask us to reinforce the safety aspect for your peace of mind.
    It seems like an uphill curve for you now, but no need to be anxious. In a short time all this pool stuff will start to click.
    I estimate your Stabilizer level should be about 30ish ppm after you add it.
    The amount of bleach I recommended will get you to about 2-3 ppm (10% of the stabilizer level) which is perfectly fine for you to swim and keep your pool sanitary for the time being.
    Your Chlorine level will drift down each day due to exposure to UV from the sun, and doing its job of oxidizing persperation, lotions, and skin cells etc from swimmers.
    Just add a little bleach every day to replenish the chlorine until your test kit arrives and you will be fine.
    Once the test kit comes in, we can help tweak it so you have a nice sparkly troublefree pool.
    Quote Originally Posted by sunfyer View Post
    Divin Dave,
    Jun 2016
    Bangor, Maine
    6
    Oh man am I wishing I took chemistry in high school now! I received the kit tonight and it is overwhelming to say the least! I'm not even sure how much of the water sample to fill the tube with lol
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    It's all here, with videos. https://www.taylortechnologies.com/p...tNumber=K-2006
    The individual tests are listed in a menu below the video screen
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,569
    Do I EVER know what you mean! I went so far as to order my test kit BEFORE I ordered my pool! I wanted to make sure I could do the tests! Well it turned out I could AND it was fun!
    Make sure to keep a log of your test results. That will help you learn your pool's needs over time.
    If you have ANY questions ask them no matter how small! We have all asked the same question!
    Kim
    38,371
    The instruction card should be pretty self-explanatory ... and the video help too.
    Jun 2016
    Bangor, Maine
    6
    Thank you Richard! Those videos are exactly what I needed!
    Thanks Kim! That was a smart move to order the kit first! My pool was a last minute birthday present for my 7 year old. I had no idea at the time what it would involve beyond leveling my yard and filling it! lol
    Jun 2016
    Bangor, Maine
    6
    Alright so I tested and assuming I did it right my Free Chlorine is 9.4 and no Combined Chlorine is present. And my CYA is at 90ppm.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,078
    That's a really high CYA. How much did you add?
    Also, could you add your pool info to your signature please? Thank you!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
