Results 1 to 9 of 9
Thread: How to add DE without skimmer
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    I'd like to start filtering as my pool fills, but how do I add DE if the water level is below the skimmer?
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: How to add DE without skimmer
    Put it in and old sock, like a tube sock and tie that to a pool noodle. But you want enough water so that sock isn't resting on the bottom.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by AimeeH View Post
    No, don't do that. That's for CYA.
    If you can isolate the main drain so you can actually pump and filter, and it's not too late, just wade in when the water's less than a foot deep and gently add DE to the drain. Maybe mix it up as a slurry in a bucket so you can aim it at the drain accurately. You don't want it spreading out in the pool.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    OH my gosh.
    Horrible reading on my part. Thanks Richard.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    About 4 feet My thought is small batches in the pump basket?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by ckk81 View Post
    Sent from my SM-G920P using Tapatalk
    You'll just be sucking air before you can react. I think you'll just have to wait.
    You could prefilter the water going in to get some rust by packing a bucket full of polyester batting and setting the hose it at the bottom so it all has to percolate up through the layers to overflow into the pool.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    OK got a bit nutty. Put a quart of DE in the bottle. Filled with water to make a slurry. Hopped in pool. Swam down to drain. Squeezed bottle directly on top of drain. Rinse and repeat.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    You win the McGyver award
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
