Results 1 to 10 of 10
Thread: TF-100 First time results. Now what?
    hauntedmansion138's Avatar
    Jun 2016
    Weyers Cave, VA
    35
    Just got my TF-100 kit and did the tests. Now what?
    FC - 5.0
    CYA - 20
    TA -330
    CH - 300
    No combined chloramines
    How do I test PH with this kit?
    16x32 52" AG oval Century pool (14400 gallons we think). Vinyl liner. Hayward Pro Series sand filter S166T model. Hayward Power-Flo Marrix SP151021XEHC 1HP pump. Had the pool since 5/27/16. TFT-100 test kit. Water delivery initially, but use well water to top off when needed.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Re: TF-100 First time results. Now what?
    Just use the red side of the blue box test.
    How's the water look?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Weyers Cave, VA
    35
    Ahhh I was wondering ok.
    the water looks great actually. I'm going to redo the TA test again to be sure though
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    You don't have to do the OTO chlorine test since you did the FAS-DPD test. Just do the pH side. All the tests are on youtube.
    Jun 2016
    Weyers Cave, VA
    35
    pH is 7.8 and did TA again. TA is reading 250 now. Pfew much better
    Looks like I should add acid but pool math does not show how much
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by hauntedmansion138 View Post
    Sure it does!
    First you need to input the pool volume. I doubt your pool is filled to the very top, so call it 4'. Down at the bottom, it says a 16x 32 oval 4' deep holds 13700 gallons. Put that in as your volume. Plug in 7.8 as pH and target 7.3 (Leave some room for error in case the pool is even smaller than 13,700) and then enter the now TA. 61 fluid ounces of 31% acid to lower pH.
    As a side benefit... Effects of Adding Chemicals says that 61 ounces of acid will lower TA by 17.
    It'll all make sense soon once you start doing it. A lightbulb will go off above your head and you'll understand.
    Jun 2016
    Weyers Cave, VA
    35
    I noticed more of the TA acid adding instructions in the PH section which said to add 32 oz based on my calculations.....so that's what I did.
    since my cya seemed kind of low, in about an hour, I'm adding more stabilizer too and keeping an eye since that dreaded puck is already gone (good). I have everything I need on hand, including you guys just in case.
    hope I've covered it all
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    478
    pH from 7.2 to 7.8 is ok. Depending on what you are using to add FC, you might just leave the pH alone and enjoy the pool. Pucks will lower pH over time. If you have any aeration (waterfalls, returns causing disturbance at the surface, etc) it will raise pH. 7.8 is just a little uncomfortable on my eyes. I swam yesterday and the pH was 7.4 - I opened my eyes underwater frequently and it doesn't burn at all.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Jun 2016
    Weyers Cave, VA
    35
    I have my return into a small fountain/waterfall like thing which is why the PH might be slightly higher. I'll put it back to normal and see what it does. For now, I'm swimming
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Oh yeah!
    Kim
