Thread: Pump emptying into filter when it turns off
    Feb 2016
    CYPRUS
    56
    For some reason my pump empties itself into the filter when it shuts off. It does not do it all the time, I am totally baffled by it, anyone got any ideas please?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump emptying into filter when it turns off
    It is most likely an air leak and probably in the pump lid gasket. Inspect the gasket for any cracks and lube with silicon pool lube. Also check the pump drain plugs.
    Mark
    Feb 2016
    CYPRUS
    56
    Thank you, I will do that today...
    Feb 2016
    CYPRUS
    56
    Quote Originally Posted by mas985 View Post
    Seems ok now, looks like it was the drain plugs, thank for your help..
