Thread: Pool light grounding wire nicked
    Apr 2014
    United States
    8
    As I was changing out an old, leaking pool light we ran into some problems requiring brute force. Unfortunately, the plastic coating on the grounding wire attached to the light niche with potting compound got nicked in the process in 2-3 places. Can I apply a waterproof sealant (I was thinking of using G-flex) over the nicks or do I need to replace the entire grounding wire and potting compound?
    Scott
    30,411
    Re: Pool light grounding wire nicked
    The good electricians will be along soon but I think the grounding wire can be nicked or exposed without harm.
    Apr 2013
    Sacramento, CA
    2,769
    Technically that is a bonding wire NEC 680.23 (B)(2)(b). A "bonding jumper" in the words of the code. The purpose of the potting compound and insulation here is to protect the copper line from the deteriorating effect of the water. So whatever you can do. This is not major critical because the water is already bonded.
    If you are replacing the fixture I would replace the wire. If you do replace it its not normal wire its #8 considerably thicker than normal. And I would get stranded. Where I live the inspectors are very picky about the potting compound. Sacramento County actually requires that they leave the empty container in the niche so the inspector can tell what was used. So you would need to get that at an electrical supply house, I know they don't sell it at HD.
    Jun 2012
    western NY
    1,559
    Are the nicks all the way thru to the copper? I am assuming so. A lot of this depends on where in the conduit the nicks will be. If they will be in the wet portion I would definitely change the wire as any corrosion from the pool water will eventually compromise the wire. At very least, I would get a pool rated potting compound to protect the damaged area and then cover it with heat shrink tubing. Of course this may make it hard to pull back into the conduit.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
