Thread: First time pool owner who found out that Automation is not automatic....
    Jun 2016
    Phoenix, AZ
    38
    I recently had a new pool built in my backyard back in April and everything was great until Pool Startup. Startup was a disaster, mostly because my pool builder outsourced their startup guy and he had no idea what he was doing with the system I purchased (system information below).
    Hardware
    10,700 gallons Freform pool w/waterfall
    Infloor cleaning system
    EasyTouch 4 w Screenlogic
    Intellichem
    Intellichlor
    Acid Feeder
    Intelliflow VS
    Stats
    PH - 7.4
    ORP - 696
    TA - 80
    CYA - 80
    Salt - 4050
    FC - Out of control
    Chlorine - Out of control
    After going back and forth with my Pool builder and their startup guy for more than a month, they finally sent out a Pentair rep who was able to get my pool going correctly (or so I thought). Up until about a week ago everything was fine, but I noticed that my ORP was constantly going up and down and my intellichlor was running constantly. After reading the manuals and this forum I figured out that my CYA was probably the culprit. The genius that I am thought that since the Saturation index on the intellichem controller showed CYA as 0 that I didnt have any in my pool so I went out and bought some. I added 2lbs of stabilizer and let my system run for 24 hours to get it through the system. I then went back to my intellichem and noticed the CYA was still showing 0 and went back to the manual only to find out that it does not measure CYA (at this point I am losing my mind and immediately thought I screwed the pooch and might have to drain my pool because prior to the salt, I was using Trichlor). I immediately went to a pool store (no names) and had my water tested, thankfully the CYA was fine, but my chlorine was through the roof, literally off the scale. I manually configured the ORP on my intellichem to something super low like 510 so that it would not kick on and pump anymore chlorine into the pool. After reading several posts, it seems like ORP is not suitable for use with intellichlor, especially with CYA of 80.
    TLDR:
    My question is, how do I bypass the ORP and control the intellichlor by percentage? I have seen several users on this forum say they are doing just that, but not how they did it.
    Thanks in advance!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: First time pool owner who found out that Automation is not automatic....
    Welcome to TFP
    Not many of us have those type systems, it may be a while before someone see's this.. You may change the title to "Bypass ORP and use intellichlor" instead, it may help someone to see it
    Jun 2016
    Phoenix, AZ
    38
    Quote Originally Posted by cowboycasey View Post
    Welcome to TFP
    Thanks for the heads up, I will do that!
