Results 1 to 11 of 11
Thread: Intex Pump upgrade with "Dual Suction Outlets" pool
    Jun 2016
    Medford
    1
    ANyone upgrade a pool from the 1000gph pump to 1500 or higher and have the "Dual Suction outlets"
    Basically, I have 2 outlets that go to a T connector before hitting the 1000gph pump...
    I bought the B hose adapters and plungers to upgrade to a 2500gph, but not sure how to actually connect everything....
    The manual only shows a 1inlet/1outlet configuration and has one page on the "Dual Suction" Setup....
    Looks like Intex makes a "T" style plunger for this setup, but I cannot find a P/N on it...
    Any help is appreciated.....
    Jul 2015
    Charter Oak, California
    273
    Re: Intex Pump upgrade with "Dual Suction Outlets" pool
    I installed a 12 x 24 Intex Ultra Frame last year. Mine has the dual suction set-up. What you're looking for is listed on the parts list as:
    REF. NO. 33: SPLIT HOSE PLUNGER VALVE; Spare Part No. 11872.
    On my parts list, the same spare part number is listed for all four sizes of the rectangular Ultra Frame Pools that use the split suction set-up. You can go to the Intex web site and look at or download the owners manual for the "Rectangular Ultra Frame Pool" as well. The parts list I'm looking at is on page six.
    Hope this helps...
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,451
    Nice post Schnozz!
    what are the hose inlets on the split plunger valve? it looks like 2 1.25 with a 1.5 on the bottom?
    15' X 36" intex quickset pool
    May 2012
    Caledonia, MS
    123
    Quote Originally Posted by hebrews13:16 View Post
    Exactly
    Intex 22x52 - New 2017
    3/4 HP Doheny Pump
    16" Hayward filter
    Intex SWG
    Jul 2016
    mason, michigan
    38
    Also, you don't use the b adapters. Just the 2 small hoses that connect to the dual valve. Then the larger tube to your pump just like it was new.
    Intex 12x24x52 prep begins now!
    Hayward 18" Sand filter 1.5hp matrix pump
    Hayward aq-trol-rj swg
    awesome Thanks!!
    DigbyAllen's Avatar
    Westchester, NY
    113
    Does anyone make a 3 way valve that supports 3 Intex 1.5" hoses? The only one I see on the Intex site (referenced above in this thread) has 2x1.25" and 1x1.5".
    Jim
    Intex 15' x 42" -- 4,000 gallons
    installed August 2012
    Intex 2650 sand filter, Hayward skimmer
    TF-100 test kit, TFP method
    May 2012
    Caledonia, MS
    123
    I don't think so. I looked for the same with no luck.
    Hard pipe the two suctions into one and then connect using the Intex hose to the pump if needed.
    3/4 HP Doheny Pump
    16" Hayward filter
    Intex SWG
    Jun 2010
    Levelland Texas
    125
    Re: Intex Pump upgrade with &quot;Dual Suction Outlets&quot; pool
    Where do we find that part that you've listed?
    Quote Originally Posted by Schnozz View Post
    Hope this helps...
    Where do we find that part that yo'uve listed?
    Quote Originally Posted by laweatherred View Post
    corvoxpoolandspaparts.com
