Thread: Slamming is done, now SWG?
    May 2013
    Chandler Arizona
    78
    I am in the process of Slamming my Pool, But once I get to the point that the FC is good. and is drifting down to normal levels. At what point can I turn my SWG back on to maintain?
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    Jun 2014
    15,174
    Re: Slamming is done, now SWG?
    As soon as you pass the SLAM and begin to let the FC drift back down to your target, start adjusting your SWG % rate to maintain that desired FC target listed on the Chlorine/CYA Chart (link below).
    May 2013
    Chandler Arizona
    78
    ok, so my FC slam target was 28. As I drift down toward 5 FC. I want my SWG on as soon as possible? correct. or do I wait til its close to my normal target 5ppm?
    Jun 2014
    15,174
    You can let it drop and get closer. Your FC may take a day or two to finally get back down to around 10 or so. Once you know the FC is around 7-8, that's probably a good time to let it start working again. If you elect to start it sooner, it won't hurt anything, just be some excess FC really.
