Thread: Propane Heater or Heat Pump?
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    My current propane heater (Jandy Laars LX400) has died. Need to replace it. Pool details in signature below. I'm in SE Florida. Would like to know whether a heat pump is a better option than another propane heater, given my geographic location.
    Mostly looking to heat the spa (see photo here). Would rarely heat the whole pool.
    I have an iAquaLink so would prefer Jandy equipment to preserve full control.
    Thanks!
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Propane Heater or Heat Pump?
    Stick with the propane gas and be happier that you didn't switch. Especially if you plan to use mostly on the spa it will provide you with the quickest heat up times.
    Consider getting a Raypak/Rheem 266K BTU unit since you are only heating the spa.
    All heaters will work perfectly with yours and any control system.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
