Thread: pumping options
    Jun 2015
    edgar
    5
    pumping options
    Has anyone tried to use a diaphragm pump such as surflo's 8000-033-236 for injecting chlorine? The biggest issue I see is that they may pump too much, too fast. The lowest flow I have found is around 1GPM. A pump such as this would pump all I would need daily in 10-30 seconds or so. Has anyone experimented with this type at all?
    28' above ground pool, 48" deep. Sand filter, Hayward oncommand automation, solar heater
    Jun 2015
    N Tonawanda, NY
    470
    Re: pumping options
    Sounds way too fast to me. Can you get a timer that would run for less than a minute?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Jun 2015
    edgar
    5
    Re: pumping options
    A timer or timing relay would be easy enough to find but are there other, similar type pumps available? Something that would have much less output such as 1/8 gpm would be sufficient.
    Jun 2014
    Hauppauge, NY
    17
    Re: pumping options
    you could use a flow restrictor to slow down the flow into the pool. It will create more back pressure on the pump. You could just use a needle valve to slow the flow down and have a tee between the pump and valve where the excess flow gets pumped back to the storage tank.
    -20' x 40' Inground vinyl - 35,000 gal
    -Hayward super pump 1.5hp - 1.5" pipe
    -Hayward Sand Filter S244T
    -Aquabot Classic (old but still works)
    -Stenner install in progress.
