Thread: After 2 years of problems, a new filter was the solution. Hallelujah!
    May 2016
    Hudson, MA
    10
    This is my 3rd season with this new to me pool. Last year was basically a total loss. I was never able to get my pool clear and had other things to spend money on. I closed it early in July and accepted I lost the battle.
    This year, I learned about tfp. I found a renewed motivation to fight the good fight and turn my pool blue again! I did the deep filter cleaning; I tested the water, I shocked, I scrubbed; I scrubbed, I shocked...but my pool just wouldn't improve. It was so frustrating. I knew my multi-port valve had issues and always suspected my filter might be junk. I debated replacing just the sand thinking it must be 'worn down'. Then I figured I'd fix the multi-valve too.... then I suspected a lateral or two must be broken, I should replace those as well. Then finally, I realized my 22" Hayward S220T filter was too small for my pool (29k gal), so I pulled the trigger to upgrade to the 24" S244T and replace everything.
    Thankfully, installing the filter wasn't too problimatic. Without too much trouble, I turned this:
    into this:
    Here is how my pool used to look:
    And here it is this morning, about 36 hours after the new filter installation:
    A few points I thought I'd share. First, my center pipe was cracked the whole way. The laterals basically weren't connected to anything. Speaking of laterals, 4 of them were cracked. I've basically been recirculating instead of filtering for 2 years straight. No amount of shock or testing would ever overcome this.
    Also, I thought it worth mentioning the sand used previously was junk. Not only was the amount too low (presumably lost from years of having a cracked center pipe); but it was far too course. On the left is the new sand, on the right is what came out of my old filter. Notice how much bigger the grains are.
    My multiport valve was pretty screwed up too. Water would come out of the waste line regardless of the setting, sand was inside and grinded when turning. Overall, it's clear each component of my filter was contributing towards my overall pool's failure.
    Thank you TFP for all your help. Pool School, Pool Math, the amazing knowledge found on the forums, and the incredible help offered by kind folks here are invaluable. You guys rule. My 5 year old thanks you, I will gladly contribute to keep this site thriving.
    Cheers and happy swimming,
    Josh
    18x36 IGP | 29k gallons | Vinyl Liner | Hayward S244T 24" Sand Filter | 1hp Hayward SuperPump | TF100 Kit
    Jun 2016
    washington
    11
    Re: After 2 years of problems, a new filter was the solution. Hallelujah!
    its awesome that you were able to liminate possible culprits until you finally figured it out.
    24' ABG, Sparco Sandfilter, Hayward skimmer box, 1.5hp pump, City water.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Great work! Keep it filtering and get swimming!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
