Thread: Numbers good enough?
    Waggy's Avatar
    Mar 2016
    Cyprus
    19
    So, my CYA was at 320 due to 2 years of using puks and not having a decent test kit, and CA was at 400ish. Think it was more by luck than judgement that i didn't get an algae bloom before i did lol.
    A couple of weeks ago i virtually emptied the pool and filled with tap water, i had to use puks for the 2 weeks i had to wait for CalHypo granules, because its difficult to source liquid chlorine/bleach here, i'm having to go down this route.
    Anyway, here are my new figures,
    FC 5.5
    CC 0.05
    pH 7.6
    CA 80
    TA 80
    CYA 76
    the CYA has risen due to 3 puks! but will lower this now with regular backwashing.
    Poolmath says i should be at FC of 9ppm, is this the case even if my CC's are so low? i do realise my CA is going to rise over the summer, but its quite cheap here to replenish, i'm waiting for a guy to get back to me about some 12-14% liquid chlorine, but think i will have to buy bulk to get some, until then its calhypo.
    26ft x 13 ft 11000 US gallon inground vinyl lined pool, Triton TR60 sand filter, Pentair 1hp pump, poolexactZ photometer tester, From May to October 90 degrees and above pool in sun all day
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Re: Numbers good enough?
    Forgive me for asking, but do the local grocery stores not have bleach? What do people there use to bleach their white laundry?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Waggy's Avatar
    Mar 2016
    Cyprus
    19
    yes, 3%, its a small island we can't get hold of anything worth using, i'd need to half empty my pool to get 9ppm lol
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    According to PoolMath, you'd only need a little over 3 gallons to get to 9ppm. Yeah, that's a lot but better than pucks.
    And yes, your target is 9 with a minimum of 6 until you can get your CYA down.
    Waggy's Avatar
    Mar 2016
    Cyprus
    19
    Thanks for the reply, i've stopped using puks and have started with calhypo granules, my hardnes is quite low, so should be ok there, will add a bit more and get to that figure of 9, will keep on with my search for 5% or higher bleach, i should find out about the 12% stuff soon but they only supply dairy farms. I may have to get one of the locals involved, stuff like this won't come cheap here!
