Thread: Cleaning out the fine dust that floats in the middle of the water
    Jun 2016
    Buffalo, NY
    65
    I cant seem to vacuum up the very last bit of fine dust debris that gets into the crevices of my pool bottom.
    I go very slow and try to vacuum it up, but its so fine that it just kicks up into the water, and then floats mid-way between the pool bottom and water top until it finally settles back down an hour or so later.
    12,000 gallon AG pool | Hayward 1HP pump | Hayward Perflex DE filter (I hate DE) | Taylor K-2006 Test Kit
    Jun 2016
    Buffalo, NY
    65
    Re: Cleaning out the fine dust that floats in the middle of the water
    I guess i'm the only one who deals with this haha.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Brushing it toward a main drain if you have one or brushing it up to really stir it up so it gets circulated through filter by skimmers should help.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Next time someone is in the pool....
    Before they get out, have them run around the edge and create a whirlpool and get out while it's still spinning. All the debris will settle in a nice pile in the middle. Then you can sneak up on it with the vacuum. You want to suck it in before it gets pushed away by the water being pushed by the vacuum, so approach real slow.
    The other possibility is that it's dead algae. You're getting some but more is growing to replace it so you think you didn't get it. The difference between dust and algae is that clumped algae looks and acts like aquatic dust bunnies. The slightest disturbance and poof - gone. The cure for that is higher chlorine levels.
