Results 1 to 10 of 10
Thread: Install through the wall Skimmer with pool full.
    May 2016
    Madison Wisconsin
    6
    I have a Coleman 18x48 pool . id like to add a through the wall skimmer but i already filled the pool. Has anyone tried to add skimmer with pool full?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: Install through the wall Skimmer with pool full.
    Hi, welcome to TFP! You may want to drain some of the water to just below where the skimmer will be installed. You want the pool to be partially filed as it will provide some support for the skimmer. Here is a link with instructions for installing a skimmer on an intex style pool.
    Adding a Hayward Thru-the-Wall Skimmer to Intex Metal Frame Pool (PICS!!
    Love TFP? Become a
    TFP Supporter!
    May 2016
    Madison Wisconsin
    6
    Thank for the reply. I've done all the research and bought a Hayward. I'm mainly wondering if anyone on here has tried to do it with water in the pool. I don't want to drain the pool . I read on a forum of someone doing this method but I can't remember where I seen it.
    Jun 2015
    Stockholm, Sweden
    250
    You dont need to drain the pool, but you should definitely lower the water level to below where you make the cut.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jul 2014
    Lexington, NC
    109
    I installed one last year and best I remember I did not drain my pool. You simply make the cut after everything else is installed.
    15'x45" AGP Metal Frame - Intex 2500GHP - Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer and Accessory Kit - TF 100
    May 2016
    Madison Wisconsin
    6
    Quote Originally Posted by zea3 View Post
    This is perfect! Thank you so much!
    Quote Originally Posted by Enkpen View Post
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    I too did mine with the pool 100% filled. Just lost a little when each screw was pushed through the vinyl. I plumbed the skimmer with a shut off valve, so when I cut out the square the plumbing simply filled.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    May 2016
    Madison Wisconsin
    6
    Quote Originally Posted by philc View Post
    Thank you!
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by wizardmt70 View Post
    This ^^^^^
    And my final piece of advice... Make sure you use a #3 phillips screwdriver to tighten the screws. The larger head creates more torque and will tighten the screws that extra bit they need to make the gasket seal. I tried with a #2 and had them as tight as I could get them but still had a slow trickle. Broke out the #3, twisted on them hard, each bolt made a nerve wrecking cracking sound but the leak stopped.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    jmcdtucson's Avatar
    Jun 2014
    317
    Yeah I remember having to really crank those screws down.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
