Thread: Looking for help, what to do?
    WMS's Avatar
    Apr 2016
    Green Cove Springs,Fl.
    22
    Had the grand kids over for a swim. The youngest is just getting over from a ear infection and only 3 years old. He was wearing swimmers, he was hanging out by our bubblier. I shocked the pool after they left. This morning I found Feces on the bottom of the pool. It was clump together but when I scooped out most of it out but its breaks up and now very small fine partials. Had the water checked and only the alkalinity was off. Will chemicals take care of it or would it need to be drained?
    Thanks
    28 x 14 x 6.5 gunite pool, Sun shelf w/ bubbler,riser w/ 2' waterfall. Pool / Step Bench with (4) Therapy Jets, Ozone system, Tropical Heat on Pool - 141k BTU electric heat pump/solar Pool Heating System-six 4'x12' panels. Paramount Elite in-floor system, Jandy control with 8 VS 2.0 HP motor, Jandy cartridge filter, inline Chlorinator, H2O ozone system, 1.5 hp Jandy pump for aux system Interior Finish Upgrade1 skimmer 6returns, 4 maindrains.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Looking for help, what to do?
    Vacuum up the remaining feces and then rise off the filter cartridge. Raise the FC to SLAM
    level today and run the overnight chlorine loss test tonight. You don't need to drain the pool, and raising the FC to slam level should take care of any bacteria that may have been deposited in the pool. If you fail the OCLT then you can begin a full slam tomorrow.
    Love TFP? Become a
    TFP Supporter!
    Jul 2015
    Central Valley CA
    1,107
    Are you having visions of Caddyshack? Sorry I couldn't resist . Zea has you on the right path I am sure the visual is much worse than the impact on the water. Do you have one of the recommend test kits if so that is the best way to see how you are doing and if more is needed?
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    WMS's Avatar
    Apr 2016
    22
    Thanks I have a few test kits and test strips, the Taylor 2006 c and 5 way test kit from Pool Style that builder supplied.
    I'll get that done. thanks again.
    May 2015
    Land O Lakes, FL
    527
    All I can say is yuck I'm sure it will eventually happen in my pool but I don't look forward to the day.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
