Thread: Hayward H400IDL2 - Cannot set BO mode
    Jul 2015
    Houston, TX
    3
    I have 2003-vintage H400IDL2 Low NOx heater. Pool controls are Aqualink RS6.
    A few years ago the temperature sensor circuit on the RS6 board failed, so I have been manually turning the heater on/off since. (Previously the heater was in BO mode for remote operation.) I just upgraded the RS6 to iAqualink with the IQ900RS kit (rev R firmware). Pool temp via the RS6 is reading correctly now.
    I cannot seem to switch the H400 back to BO mode for remote operation. (I note the Standby light on the heater only illuminates when the pump is running, which is believe is the correct behavior.)
    With the filter pump running, and the H400 in Standby, I hold the DOWN arrow button and the MODE button simultaneously (for at least 10 seconds) but the display just stays blank. From what I've read, it should switch to BO. If I just press mode I can cycle between Pool and Spa with the temp displayed, and I can set the temp up and down without any issue.
    Any ideas? The heater functions perfectly otherwise. Note this is an early H400IDL2 with the white circuit board that is integrated with the display module.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Hayward H400IDL2 - Cannot set BO mode
    Are there any other error codes being displayed on the unit? If so, you have to clear those first before you can set the unit in bypass mode.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jul 2015
    Houston, TX
    3
    Thanks for the reply. There are no error codes visible. When in Standby the display is blank. If I switch to SPA or POOL the blower/heater kicks on and the water temp displayed; if i push the UP or DOWN arrows the set temp is displayed.
    About a year ago I had the "AO" error code a few times after the blower came on (blower vacuum switch problem), but it would go away after a few attempts to ignite. I've put ~100 hours on the heater since the last time I saw the AO error.
    Could there be error codes "stuck" in the controller "memory"?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    You could try killing all power to the unit via a breaker and see what that does.
    Paul
