Thread: Solar Cover
    Apr 2012
    South Dakota
    87
    Solar Cover
    I have an auto cover that is usually closed but would a solar cover help heat the water better?
    Not sure what the best method would be to heat the water- Open during the day with the auto cover closed at night?
    Thank you
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    Jul 2015
    Central Valley CA
    1,107
    Re: Solar Cover
    Auto cover is probably best at night to keep the heat in assuming the auto cover blocks sun light a bubble cover during the day would certainly give you more heat. I have been playing around with the bubble cover on vs off during the time of day the sun hits the pool and as long as there is not a whole lot of wind I only see at most a 2 degree increase with the cover on. Generally I leave it on during the day M-F since I am at work but have it off during the weekend for easy access to jump in when ever the mood hits.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
