Results 1 to 13 of 13
Thread: Help identifying a stain
    Feb 2015
    Fairfax, CA
    13
    Hey folks!
    I am hoping you all can help me ID a stain. First a little history:
    Over the winter a few of our looploc pool anchors became dislodged from the wall during a heavy snowstorm. It didn't seem to let in too much extra debris but when I opened the pool in mid-May I noticed the heavy staining you see in the pictures this was not there at all at the end of the season or during any of the other seasons. The plaster is starting to degrade some but still probably had/has another season to it before it need to be resurfaced (at least in my opinion). The stains and surface are now very rough and seem to be calcium deposits but I am not sure and wanted to ask the forum. If they are indeed calcium, is there anything I can do short of sanding them down, acid washing or resurfacing?
    Also, I have tried Vitamin C, so I don't think its a metal stain.
    Thanks in advance!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Re: Help identifying a stain
    If you can get some dry acid, try that in a sock.
    Sometimes metals and scale will combine. In that case, you eed to release the scale first.
    If you want to confirm this is what happened, try the dry acid followed by the vitamin c.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Feb 2015
    Fairfax, CA
    13
    Would Clorox Ph Down work for this or do I need Sodium Bisulfate?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Should work fine
    Helpful Links:
    Feb 2015
    Fairfax, CA
    13
    OK, I tried dry acid in a sock last night and it didn't seem to have any visible results. Any other suggestions or courses of action that I should take?
    Thanks!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    That looks like the plaster is worn through to me.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Feb 2015
    Fairfax, CA
    13
    Quote Originally Posted by Mr Bruce View Post
    Is it possible for that to happen just over the winter? It didn't look at all like that in Fall when we closed the pool up.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    There wasn't one tiny spot that looked like that in the Fall?
    What is your CH and CSI normally?
    Feb 2015
    Fairfax, CA
    13
    Here is what the pool looked like at the end of September.
    Honestly, I am not sure what the CH and CSI is as I don't have a full test kit - The pool has been maintained through a service the last two years (blasphemous I know)
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Wow. Did you fire the pool service?
    The first step I guess from here will be to determine if you're taking over on the pool. If you are, get yourself one of the recommended test kits at TFTestkits.net and post up your readings and we can try to sleuth out what's going on
    Helpful Links:
    Feb 2015
    Fairfax, CA
    13
    Quote Originally Posted by Swampwoman View Post
    I haven't yet. I am giving them a chance to rectify the situation before I completely get rid of them.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Makes sense. Let us know what they come up with.
    Helpful Links:
    Apr 2009
    Austin, TX
    24
    Greetings. Hopefully it's not rude to jump in on someone else's post, but I also have a staining issue. It's been this way for over a year with little to no change. Been TFP compliant for at least a year now. The pattern does follow how I add salt to the pool. I used to use the larger, compressed salt, but have switched to the smaller crystals. Today' readings.
    Cl 7.0
    pH 7.8
    FC 9.5
    CC .5
    CH 425
    TA 80
    CYA 58 (up from 35 last weekend)
    txreap
    19.5K, IG plaster pool, with spill over spa, circa 1997. Goldline Controls SWG, T-15 cell. Pump-Centurion single speed. Sand Filter- Pentair Tagelus 60D installed '13. Polaris 360 with 1/2hp Booster pump. Austin, TX. TF-100 Test kit (with stirrer)!
