Results 1 to 12 of 12
Thread: We need a plant next to pool, but which one?
    May 2016
    AUSTEX
    52
    As a visual barrier to a home next door, we have been thinking of a large plant in a pot, which would be physically very close to the spa. We would need something in the 6-8' height and 3-4' wide eventually. One suggestion was a cherry laurel, but I realize I have no idea what would work from a "debris generator" standpoint. I thought of clump bamboo, but just concerned about sloughing off of the stalks. What would you suggest?
    18,000 gal, IG kidney w/ spa, Pebbletech, 60 DE filter, 2 skimmers, auto chlorinator, 2.0 hp pump, Dolphin M400
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: We need a plant next to pool, but which one?
    Well....if it's "pretty"..it's gonna flower, and end up in your spa!. How about a decorative section of fence--lattice maybe---with some kind of vine on it. Carolina Jasmine?
    Jul 2015
    Central Valley CA
    1,109
    I would be very cautious about bamboo, there are literally hundreds of varieties so you might be able to find one that will work but it can be very aggressive / destructive and hard to get rid of should you decide you don't like it. Do a Google search for "can you plant bamboo near a pool" most of the results will be why you shouldn't.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mar 2016
    Easley, SC
    381
    I would not suggest bamboo either!! The previous owners thought it would be a great privacy around the pool. It does provide privacy but it also provides hundreds of leaves in the pool every time the wind blows. It is also very hard to control. I have it shooting up 20 feet from where it was planted. The roots are are very hard, just like the mature bamboo and run everywhere!
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    May 2016
    AUSTEX
    52
    Re: bamboo, this will have to be in a container anyway, and about 10 ft above ground level, so rhizome spread wouldn't be an issue, but the debris generated would. I will take a photo of the location, and save the 1000 words!
    May 2016
    AUSTEX
    52
    The pot/plant would go on the other side of the spa but on this side of the fence. This is a temporary solution, (2-3 yrs.) and I'm really looking for species direction. We will be planting a tree on the backside which is 10-12' below the deck surface, so it will take a few years to get to the desired height.
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Maybe the banana tree? I'm considering Musa Basjoo for near our pool. As I understand they grow tall quickly but you do need to cut them to survive winter.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    How about 3 arborvitae...one to the right of spa, one directly behind, one to left...and they get tall
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    May 2016
    AUSTEX
    52
    Good ideas! I'm liking the Muso Basjoo idea for it's tropical appearance. The arborvitae would probably be less imposing (spreading) since the deck area there is only about 40" wide. These are choices I probably wouldn't have considered.
    Aug 2015
    Cypress
    1,679
    Quote Originally Posted by simplemind View Post
    Yea! Then we helped.
    May 2016
    AUSTEX
    52
    Quote Originally Posted by twinkiesmommy2009 View Post
    Yes indeed! Found a Muso (not sure if it was a Basjoo) at Home Depot ~ $15 that I'm going to try out. I'll post later.
    Aug 2015
    Cypress
    1,679
    Keep us posted.
