Thread: Spell checking post?
    Mar 2007
    Ontario
    211
    Hi:
    Is there a simple way to spell check posts? Thanks
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Round Rock, TX
    529
    Look at the bottom right corner of the posting window.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Mar 2007
    Ontario
    211
    Thanks, I was focussed at the top. Did see that over there.
    Arizona
    924
    Am I the only one who sees it spell check in real time as I type my post? Whenever I spell anything incorrectly it immediately puts a light underline in red under my incorrect word, which I can right click and choose the correct spelling. Just like when you are typing a document in MS Word or other word processors.
    I thought it was a cool new feature of this forum, but maybe it's something about my system, instead. It doesn't do this on other forums, though. Anyway, I love this feature.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Buggs,
    Since I downloaded the most recent update of Firefox (2.0.0.4) (turns out I was running an older version) I also have a spell checker for forms and forums like you describe... 'realtime'. It is not a feature of TFP. I love it, too!
    I used to use the google one, but would always forget to click it before submitting a post... same thing with the one for TFP.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Arizona
    924
    Hahahaha! Ohhhhh! I did download the 2.0.0.4 Firefox at about the same time as the new look of TFP. I didn't even think about that.
    However, none of the other forums I regularly visit do this. So, perhaps it's a combo of newer versions of phpBB's and the latest Firefox.
    Thanks for the info.
    Buggs
