Thread: Need help determining cartridge filter size
    Apr 2014
    United States
    21
    Hi, lat year my cartridge filter wore out so I threw it away, not realizing that they come in different sizes. I've looked at the specs of my swimpro voyage filter and it gives me 3 different options, but I'm not sure which is best. Here is what I have:
    Filter: SW150MDDVPAKS
    Pump: SW159412STL (Hayward Dual Speed)
    Pool: 27 ft round above ground
    The sticker on the filter says I can use the 100 sq ft, 150 sq ft or 200 sq ft. I'm guessing since the model number has 150 in it, I should get the 150 sq ft right? Thanks for your help!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Need help determining cartridge filter size
    Yes, correct. There is usually a box that is checked or hole punched on the label also showing which model it is also.
    Apr 2014
    United States
    21
    Thanks! Unfortunately there was nothing punched on my label but I will go with the 150.
