Thread: Closing off returns
    May 2015
    Fort Mill, SC
    179
    Closing off returns
    I have a 20000 gallon pool with a 1/2 HP pump. I am planning to install new 3/4" return jets. Is it safe to close off 2 out of 3 of them using the Jandy valve? The reason I ask is I would like to increase the flow rate to a fountain for a few hours here and there.
    May 2015
    katy, tx
    31
    Re: Closing off returns
    I close mine off to divert to the waterfalls or to make the bubblers go high for the kids. I have actually made a water gun for the kids and an air cooler (evaporative) coming out of the bubblers and shut everything else off. My PB kept a return always flowing through the spa just in case everything was turned off, which saved me once. The main thing as far as I can tell is to make sure the water can return somewhere. it will affect circulation somewhat so you may not want to do it 100% of the time.
    16,500 gallon in-ground pool and spa with Quartzscapes Midnight-blue and pretty sparkles
    Aqualink RS with PDA
    Jandy Pro Series Plus HP 2 HP 2 Speed Pump
    Jandy CV460 Cartridge Filter
    30,419
    Yeah, perfectly safe. Your psi will go up but that's very acceptable.
    May 2015
    Fort Mill, SC
    179
    Good to know, thanks. So here's a photo of my pool equipment. In the foreground is a Jandy valve, with the inlet coming in on top, and the two outlets connected to the return jets going out the side and bottom. So my plan is to close off one of those outlets and see which return jets shut down. I assume two jets are on one line, and the third jet is on the second. That is an assumption, as this pool has had all kinds of funky stuff going on. Worst case, all three jets are on one line, and the other line is just capped off. Is there a way to tease this out without just throwing the valve and seeing if the pump deadheads?
    May 2015
    Fort Mill, SC
    179
    Heck with it, I took a chance and threw the valve. One of the returns closed off. So that's good. It's not the two I want off, though. So for that I have to get that Jandy valve in the other position. I have another thread going on that. Apparently I need to remove that front plate and rotate the assembly 90 degrees. So that's my next project.
    30,419
    Folks trying to help you will find that VERY confusing. Keep your "story" in one thread......it's MUCH better.
