Results 1 to 7 of 7
Thread: Ordered pool cleaner without reading description
    May 2016
    Lincoln Park
    10
    Hey guys.
    I ordered the intex automatic pool cleaner without reading the description. It hasn't arrived yet and I'd really like to make it work.
    Here's the problem. I have a 1.25" outlet jet and it says you need the 1.5" outlet for it. I've seen adapters for the fittings on the outside of the pool, but can't find one to convert the outlet in the pool from 1.25" to 1.5".
    Anybody know of anything?
    Thanks again
    Nick
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Re: Ordered pool cleaner without reading description
    "outlet jet" is a term with which I'm not familiar. I know "return jet" and "skimmer." (I'm a newbie pool owner, but a retired plumber.
    Check plumbing PVC fittings at your hardware store. What connection types do you have for each size (threaded, barbed, socket)?
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Jun 2015
    Stockholm, Sweden
    250
    Is yours an Intex pool? The cleaner connects to the outer thread of the return strainer, which looks like this: Large Strainer - Intex
    If you dont have an intex pool, you could get this part, but then you would have Intex thread on the outside of the pool as well, which might be an issue if you are using non-Intex hoses.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    May 2016
    Lincoln Park
    10
    It's an intex pool and yes it's the return jet. I have the "small" return jet however, not the "large" one.
    May 2014
    Corona, CA
    21
    I have the same cleaner and have both the 1.25 and 1.5 strainers. I believe the cleaner will hook up to both but I will check when I get home.
    Intex 14'x42"
    Intex 14" 2800gal sand filter pump
    Jun 2015
    Stockholm, Sweden
    250
    I just checked and the cleaner hose has the standard Intex hose fitting and an adapter to fit the larger strainer thread in the picture above (though the inner thread, not the outer as I wrote). So if you can screw a regular Intex hose onto yours, you should be fine.
    May 2016
    Lincoln Park
    10
    Thanks!! That's good news!!
