Results 1 to 9 of 9
Thread: Late opening but I have to say thank you
    Mar 2015
    Mount Pleasant, TN
    59
    Red face Late opening but I have to say thank you
    I had a late opening this year, just opened (June 5th). I decided to redo my plumping, so it took some time to complete. However, I need to say thank you to all on this forum that helped me out last year. Without your help, I wouldn't have had such a successful opening. All I had to add was a bit of stabilizer and chlorine.
    BTW, I found 10% liquid chlorine at Walmart for $2.50 per 128oz. What a steal!
    I still need to vacuum the bottom a bit, but the water is 90% clear and PH and TA was stable already. I do have one small leak on my back flow joint, which I'll need to fix. Not sure what happened there, but without further ado, pictures!
    Pool Stats: 24" Round Above Ground - Vinyl - 13,500 Gallons | Filter: Hayward Sand S180T | Pump: Hayward Power-Flo Matrix | Testing Kit: TF-100 | Mount Pleasant, Tennessee
    30,432
    Re: Late opening but I have to say thank you
    Sharp looking pool AND a VERY sharp looking aerator. Will you use it to cool the pool this summer??
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Looking good! Nice pool and nice place too!
    If the time is right please consider supporting TFP, there are some nice perks.
    More here, CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Mar 2015
    Mount Pleasant, TN
    59
    Most likely. The weather is already calling for 100+ degree days. The pool is in full sun for around 9 hours, so I'm assuming the water will get up to around 85.
    May 2016
    Troy IL
    476
    So aeration can cool the water in addition to raise the pH?
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    38,548
    Yes. The act of evaporation cools the water.
    Mar 2015
    Mount Pleasant, TN
    59
    Plus it's fun to play in. The ball value also acts as a pressure control. Fully open it reaches to the middle but if I want a small fountain, I can open it half way.
    DFW, TX
    24,517
    It especially cools the water if you run it at night.
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,539
    Beautiful setup! Thanks for sharing!
    If only heating a pool required a pvc with some holes in it....
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
