Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Show off your test kit!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    There was a thread quite a while back that I thought was pretty fun and gave me some ideas (that I haven't followed through on... yet!). I thought I would get one going again.
    So here's my test kit set up. It's a stock TF-100 case and reagents but I've rearranged so I can fit my SpeedStir in the box along with the K-1000 test block and reagents, sans blue box... and it closes! I also have an extra calibrated cylinder. One dedicated for chlorine testing, the other for the rest of the tests. I didn't like the bump on the bottom of the standard vials when using the magnetic stir bar. I also laminated a chart with CYA/Chlorine levels for reference. When I receive new bottles of reagent, I write the month/date right on the side so I know how old it is.
    I'm sure there are much more extravagant set-ups than mine but thought it was worth seeing what's out there!
    Isolated Spa - 345 Gallons
    Jun 2015
    Glendale, AZ
    156
    Re: Show off your test kit!
    Kit plus spares
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I found that a tackle box is the perfect format to fit all the tests+extras.
    K2006+Salt+Copper+Iron+Speedstir
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    I had to take that big CYA bottle out of mine, it seemed to leak when on its side
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Pretty much a stock rig for me.
    Attachment 35902
    themadangler's Avatar
    May 2016
    Southampton, NJ
    127
    Basic k 2006 and k 1766. Running low on cya and dpd powder of course.
    Diamond Pool 20'x40' Lazy L, approx 33,000 gal vinyl liner, Hayward s244T filter, Pentair Intellichlor Ic 40( new May 2016) replaced computer pool cpsc35, inter mastic T40404R, A.O.Smith UST1152 super pump 1.5 hp, Hayward heater, not working or by-passed, Polaris 360
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    I like the Taylor K-2006C box. It has a built in handle, instructions in the lid, and well divided sections. I bought the TF-100 and use the Taylor box.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Jun 2014
    14,970
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by pinguy View Post
    Hi there, could you provide a link to where you found it... It looks wonderful... 😊
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8400 gal, with salt and borax, INTEX 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Here's mine. I think Pinguy and I may have the same Tackle Box.
    I have all my refills in there, my Salt Test Kit, Sample Bottle, gasket lube and a couple of rags too!
    Divin Dave,
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Found this in Amazon, but I think pinguy tackle box is better
    Amazon.com : Flambeau Tackle XL 3 Tray Tackle Box (Black/Dark Gray(Black/Dark Gray, 20x10.25x10.375-Inch) : Fishing Tackle Boxes : Sports Outdoors
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    May 2016
    AUSTEX
    52
    Quote Originally Posted by Divin Dave View Post
    Nice, and it matches my Dolphin!
    18,000 gal, IG kidney w/ spa, Pebbletech, 60 DE filter, 2 skimmers, auto chlorinator, 2.0 hp pump, Dolphin M400
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    It matches my Dolpin too!
    Quote Originally Posted by simplemind View Post
    Thats the one I have too. Got mine at Walmart.
    Quote Originally Posted by Piolin View Post
    Divin Dave,
    Feb 2014
    Central Minnesota
    5,080
    I'm just going to have to step up my game in the kit department! Would be nice to fit my sample bottle in there... and my ammonia test so I can dazzle folks I occasionally help out in my area with their green pools in the spring. Need to get the dispensing sample bottle too!
    I might have to go for the pink version!
    JoyfulNoise's Avatar
    May 2015
    13,173
    Matt
    May 2016
    fort worth, tx
    123
    Construction began 5/2016. IGF pool. 41' x 21'. Jandy DEV60, Jandy 2hp 2sp pump, Polaris 280 Black Max, Rainbow 320 chlorinator, Jandy JXI 400, Jandy iAqualink, Jandy LED's. 2'x2'x10' rock weeping wall. Dive rock. Tile/Plaster: NPT Silverstone AquaMarine Decking: Stained Stamped Concrete/Stonescapes Aqua Blue with glass beads and abalone. http://www.troublefreepool.com/threa...-Fort-Worth-TX
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Hi there, could you provide a link to where you found it... It looks wonderful... 
    Walmart carries the Plano boxes as well!
    Test Kits:
    My Pool:
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Me too but of course the pink version is more expensive
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
  20. Back To Top    #20
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    TexasSplash wins! Actually all of the tackle box guys' are awesome. But I love the organization of TxS's. Can you provide specifics on which box that is?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
