Results 1 to 8 of 8
Thread: TA question
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    TA question
    FC 16
    ph 7.5
    CC .5
    TA 170
    CYA 50
    I tested my TA yesterday and was 120 we have had a good bit of rain today around 1 inch. I tested today just curious as to what the rain would do and every thing has stayed the same but the TA has gone up to 170. Should I be concerned about the sudden rise in TA?
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: TA question
    The only thing that raises TA is baking soda or test error. Be sure to wipe the dropper tip between drops and hold the bottle vertically so the drops fully form.
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    Re: TA question
    I'm new to the tf100 kit. its very likely I'm not doing the test correctly. Does it have to turn pink or completely red to complete the test?
    Jun 2014
    15,298
    Re: TA question
    It will turn more like a bright Barbie pink.
    Aug 2013
    Otsego, MN
    79
    Re: TA question
    And, you know you're done when adding additional drops doesn’t make it turn any pink-er.
    Pool/Equipment: 20'x52" round Intex Ultra Frame AGP (~8,800 gallons)--Intex SWCG (CG-28669, 15K gallon model)--Intex Sand Filter Pump (SF60110, 16", 120lbs sand, 3K gph)--Hayward SP1091LX Through-Wall Skimmer--Hard Plumbing--Taylor K-1766 Salt Test Kit--TF-100 Test Kit
    38,547
    Re: TA question
    Add drops until the last one does not cause a color change and do not count that last drop.
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    Re: TA question
    Thank you all. I re tested properly and results were TA 130 not 170
    Oct 2015
    Frisco, TX
    75
    Re: TA question
    I found that the taylor speed stir helps immensely with this test. I think it costs $25 and uses four AA batteries. Trying to shake the vial and adding chemicals proved too challenging for me.
    16.4K gal, IG Pebble Sheen, 2 X 2.7 Jandy HPPlus VS pumps, 580 sq ft Jandy cartridge, ozone, completed 4/2016, iAquaLink, Dolphin M500, Lamotte WaterLink Spin and Taylor K-2006 (to verify WaterLink), Jandy 400K JXi Heater, Jandy Nature Fusion 2 with 3" TriChlor tablets
