Results 1 to 17 of 17
Thread: Slamming
    Jun 2013
    Bel Air Maryland
    22
    Question Slamming
    I am trying to get ready for first slam but do not understand the Chlorine/CYA chart.
    I have SWG
    My CYA is 90-100
    I have no Fc
    Do not know what the Shock FC is or how to get there
    Sorry
    Donldson's Avatar
    NW Ohio
    2,917
    Re: Slamming
    SLAM FC levels are the same for SWG and non-SWG pools, so for a CYA of 100 you bring it up to 39 FC.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    is the 39 fc where the tf-100 test kit comes into play
    Donldson's Avatar
    NW Ohio
    2,917
    Re: Slamming
    Yes, you will need an FAS-DPD test to accurately measure FC that high, which is included with the TF-100. I would recommend the XL option since you will need about 80 drops each time you test to measure that high.
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    i will order that right now.Can i or should I add any Liquid Chlorine tonight to get started while waiting on it to be delivered
    Donldson's Avatar
    NW Ohio
    2,917
    Re: Slamming
    The standard holding pattern advice is 1 gallon of LC per day until the kit arrives. This will help keep things from getting much worse while you wait. That is assuming you are not running your SWG.
    Make sure you understand the SLAM procedures correctly before you start. The biggest problem people have is not understanding the specifics or stopping too early. It can seem daunting but you will get the hang of it quickly.
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    should I just turn SWG off or not add LC.I was reading alot about the slamming and may know the answer but just wanted to be sure.I should turn off SWG correct and not turn on until slam in done right.The correct way to turn off SWG is by the slide switch,Do I have to unplug cord from lower right corner of the box and unplug phone cord.Very sorry if this sounds stupid but I do not want to make more headaches for myself
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    ok I have my new TF-100 test kit and did my readings and here they are.I am going to start slamming pool on Sunday but need to use my pool on Saturday for a bunch of Girl Scouts.What can or should i do.My water is cloudy.No visible signs of algae.My salt system is off.Thank you in advance
    PH--------7.5
    TA-------------100PPM
    CH-----------------------150 PPM
    CYA--------------------------------55-60
    FC--2
    CC---.5
    TC------2.5
    30,000 gals./ In ground/Vinyl liner/Cartridge filter/A.O Smith 1 1/2 HP Pump/Pool Installed in 2008/Tf-100 test kit just ordered/Aqua-Rite SWG/well water
    Donldson's Avatar
    NW Ohio
    2,917
    Re: Slamming
    If you can't see the bottom of the deep end then I would absolutely not be letting anybody swim, much less children.
    I wouldn't wait to start the SLAM, it is perfectly safe to swim up to SLAM level. In fact SLAM level is comparable to an indoor public pool with 2 ppm FC, so it will barely be noticeable that your chlorine level is high. If you start it now you might get it cleared up enough by Saturday to consider it presentable. Drop your pH to 7.2 and raise your FC to 24 and start the process. On Saturday you can let the FC drop naturally and it will be just fine for swimming, then bring it back up after everyone leaves. Trust me, unless someone brings a test kit they won't have a clue that the FC level is over 20. CYA is a very powerful buffer.
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    i only had 4 gallons of 10% to put in tonight.Will take readings in the morning and continue to slam.I can see the bottom at the deep end very faintly
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    i started slamming and last night FC was 35 at 10 pm and this morning at 8;30 FC was at 22.Added more chlorine as per pool math.Pool water is still about the same cloudy color,Just a question could the cloudy color be coming from anything else besides algae.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Slamming
    Is the CYA 90-100 or 55-60?
    The difference is 35 FC versus 24 FC to SLAM. That could turn out to be a significant amount of bleach and $$$ when the sun starts beating on the pool.
    Cloudiness is almost always dead bleached algae. A vinyl pool won't ever have plaster dust from crumbling plaster, so it's a safe bet your cloudiness is just algae.
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    CYA is 60.I will test again in about an hour and post all results
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    last night
    FC---22 CC---1 TC----23
    CH---150
    CYA---50
    TA===120
    Added liquid chlorine as per pool math.This morning
    FC--16 CC--0 RC--16
    CYA---60
    PH--7.3
    Will be adding 2plus gallons of liquid chlorine.I do not see any improvement in cloudyness. Could it be metal particles
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    This evening ar 8;15ppm
    FC--19 CC-.5 TC--19.5
    TA--120
    CYA--60
    Will be adding 2 plus gals of liquid Chlorine
    Richard320's Avatar
    Jan 2010
    19,071
    Re: Slamming
    Quote Originally Posted by bucadam View Post
    TA--120
    CYA--60
    Are you seeing any improvement in clarity yet?
    Unless you replace a whole bunch of water, the CYA and TA won;t change much during a SLAM, so save your reagents. Stick with just FC & CC until it's done.
    Jun 2013
    Bel Air Maryland
    22
    Re: Slamming
    Yes I am starting to see some improvement.Thanks to all who have been helping.I am going to become at least a Silver supporter on payday.When do I go back and turn on my SWG
