Thread: CYA
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    CYA
    Hi, I added total of 4 lbs Clorox Stabilizer last Saturday n Sunday. Still reading 0. Added via sock method. My #'s r below. Chlorine is high because I added 1 gallon of 8.25% bleach last night.
    TH 175
    TC 5
    FC 5
    PH 6.8 due to high chlorine?
    TA 120
    CYA 0
    38,415
    Re: CYA
    What is your pool size?
    Please add your pool details to your signature as described HERE as it will help us help you.
    What are you testing with?
    The low pH has nothing to do with your FC level.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Re: CYA
    Im sorry I thought my signature was still active. One moment plz!
    Hum, still showing in my profile. Here ya go..
    Signature
    30' Above Ground 18,000 gallons, Sand Filter, 1.5 hp Jacuzzi Pump
    38,415
    Re: CYA
    Click the box to have it show on your replies.
    4 pounds should add 27ppm of CYA to your pool. What are you testing with? Is the dot obscured at all or is the mixture still crystal clear?
    30,429
    Re: CYA
    The TH you report looks like it is from test strips. They are totally unreliable as you seem to have discovered. You really need one of the two kits we suggest to manage your pool successfully. The strips are tempting but they are bogus.
