Results 1 to 13 of 13
Thread: New Pool-Iron???
    Jun 2016
    Howell, MI
    11
    New Pool-Iron???
    We just set up our pool this weekend. Not a large pool, 14' by 42". We hooked it directly to our well pump so the softener didn't burn up filling it. It's a yucky brown, which we are assuming is iron??
    We've been told to try 10 different things. We've added some chlorine. My husband is taking a sample up right now to a pool store to see what they say.
    Until he gets back...any ideas??
    38,248
    Re: New Pool-Iron???
    Welcome to TFP!!!
    While the iron is in the water, run the filter to try to filter the iron out. There are a few threads you can search for about using batting or paper towels in the skimmer to try to remove the iron.
    I hope your husband does not buy a bunch of their magic potions.
    Jun 2016
    Howell, MI
    11
    The pool place said they will not test the water because it has not been running through the filter for 24 hours yet.
    Here's a stupid question being a first-time pool owner. What is the skimmer?
    triptyx's Avatar
    Apr 2016
    1,438
    It's a hole along the waterline that usually has a basket so that it can suck in floating debris and strain it.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jun 2016
    Howell, MI
    11
    Oh, yeah we are not the fancy! Ours is just a smaller above ground pool.
    triptyx's Avatar
    Apr 2016
    1,438
    No worries! They do make skimmers for aboveground pools too, but if you don't have one, we'll have to find another way to get the iron under control.
    Jun 2016
    Howell, MI
    11
    We just bought a testing kit from the store. Had a coupon so what the heck, at least it will give us a little insite as to what we are looking at!
    38,248
    Which kit specifically?
    Likely it is not one of the recommended ones.
    Jun 2016
    Howell, MI
    11
    Probably not. It's an hth with test strips.
    38,248
    Test strips are garbage. Not even worth trying IMO.
    Jun 2014
    15,008
    HTH makes basic drop-test kits sold at places like Wal-Mart which are okay for short-term drop-testing pH, chlorine not to exceed 5 ppm, and sometimes TA, CH, and CYA. But those kits have limitations and won't test FC over 5 ppm which you may need later. I would ask you to consider the TF-100 (link below) to ensure 100% control of your testing and what your water needs. You might also consider the "Speed Stir" for quick & accurate mixing. It helps quite a bit.
    Here's some info on metals and what your options might be:
    Pool School - Metals in the Water and Metal Stains
    Jun 2016
    Howell, MI
    11
    Dye ones better?
    Jun 2014
    15,008
    Yes, the drop-test (dye) ones are better.
