Thread: Can you use an above ground vacuum for inground pool?
    May 2016
    virginia beach, va
    24
    I happened to see an intex pool vacuum for sale. The seller said it can be used for an inground pool as well. Is she right?
    25,000 gallons IG, Hayward Pro series XL, sand filter, built 1996 (i will have to check), well water with dual filtration system, K-2006 kit
    Jun 2014
    15,189
    Re: Can you use an above ground vacuum for inground pool?
    Sounds like the seller is referring to your standard manual-type vacuum head with hose that gets inserted into the skimmer when you need to vacuum. So as long as the hose being used for that vacuum fits your poolside skimmer, it should work. You could always measure the two to be sure.
    May 2016
    virginia beach, va
    24
