Thread: PH drops fast
    May 2015
    Atlanta-GA-
    69
    PH drops fast
    Hi
    I am wondering why my PH drops fast. I test my pool weekly. All numbers are fine but my PH which drops every week to 7.0 or below, so I add the amount of borax needed per the pool calculator but it still drops back to 7.0 the following week. I didn't have that problem last year. My FC is 5 and my CC is 0 to 0.5, TA is 70 and CYA is 75.
    Thxs
    Pat
    12' AG, 3200GA, cartridge filter, pool installed 6/20/2015, Taylor K-2006 test kit,
    Donldson's Avatar
    NW Ohio
    2,898
    Re: PH drops fast
    What are you using to chlorinate?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2015
    Atlanta-GA-
    69
    Re: PH drops fast
    I use tablets
    Donldson's Avatar
    NW Ohio
    2,898
    Re: PH drops fast
    Tablets are very acidic so that is what is causing your pH drop. People who use tablets should keep their TA above 100 to help offset that particular problem. Just an FYI as well, your minimum FC level should be 6 and will need to continue to rise with your CYA. You will probably want to do a partial drain soon to keep your CYA level from getting too unreasonable.
    May 2015
    Atlanta-GA-
    69
    Re: PH drops fast
    Great answer, thank-you so much. This is only my second year with the pool. Last year we went to Costco and unfortunately purchased a big bucket of tablets. When I ran out I will use bleach.
    Patrick
    30,421
    Re: PH drops fast
    A much better plan would be to immediately stop their use and switch to liquid chlorine. The pucks don't go bad and you can use them for vacations, etc.
    Saving money by using the pucks may cost you a heck ofd a lot more. Your CYA is already much too high and you will quickly be at 100+ by the end of the season. Your pool pretty much becomes unmanageable.
