Timer trippers bending
Jun 5, 2016
46
Matawan nj
Hi all. I have an Intermatic timer for my pool and it seems like every year there's a new issue. This year the clock doesn't seem to work properly and neither the ON or OFF trippers are turning the pool on or off. Surprisingly 2 different ON trippers have bent significantly. Any ideas?
Thank you
Have you done the little trick of looking thru the "peep" hole on the timer to see if the gears are actually turning? Sometimes you can even hear them and don't have to look thru the hole.
Seems like something must be binding up the lever. Work the on/off switch back and forth and see if there is anything getting stuck in there binding it up.
