Results 1 to 7 of 7
Thread: Timer trippers bending
    Jun 2016
    Matawan nj
    7
    Hi all. I have an Intermatic timer for my pool and it seems like every year there's a new issue. This year the clock doesn't seem to work properly and neither the ON or OFF trippers are turning the pool on or off. Surprisingly 2 different ON trippers have bent significantly. Any ideas?
    Thank you
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: Timer trippers bending
    Have you done the little trick of looking thru the "peep" hole on the timer to see if the gears are actually turning? Sometimes you can even hear them and don't have to look thru the hole.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jun 2016
    Matawan nj
    7
    Yes i checked and it was moving. But the big mystery is how are those trippers bending ?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Seems like something must be binding up the lever. Work the on/off switch back and forth and see if there is anything getting stuck in there binding it up.
    Hot6's Avatar
    Jun 2014
    Alabaster, AL
    27
    I had the same problem with my triggers bending. Turned out to be my ex-wife forcing the pool either on or off about the same time the triggers would be in play.
    IG Vinyl 18x36 28500 Gallon SWG Taylor K2006 Test Kit
    380 Gallon Master Spa Chlorine for sanitizer
    Jun 2016
    Matawan nj
    7
    i will give it a try. Thank you
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I bought a bag of trippers and they were assorted for different types of timers. Some wouldn't work on my timer but it had an instruction sheet which color tripper went to certain timers.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
