Results 1 to 7 of 7
Thread: Gone fishing... In the skimmer pipe.
    May 2016
    Duncan, Ok
    89
    Well this morning my daughter was cleaning out the skimmer basket and kicked a screwdriver in the skimmer and down she went. We have to use a flathead screwdriver to get the skimmer lid off. Sits in the too tight. Luckily it looks to be less than 2 ft to the 90* turn in the pipe and the screwdriver is about 8 inches long. So my wife is running to tractor supply in search of a magnet on a stick type thing or long needle nose pliers. Thank the lord it fell handle first or I'd be in trouble. Needless to say I will fin another way to get it open.
    Anyone have any any ideas?
    30k Gallons, IG plaster, Jacuzzi Sand Storm 350lb Sand filter, 1hp Jacuzzi Magnum Force pump. Taylor K-2006 kit. Jacuzzi J-D300 side suction vac.
    Jun 2014
    15,145
    Re: Gone fishing... In the skimmer pipe.
    Other ideas? Record the fishing experiment for future laughs. Maybe attach the screwdriver to a cinder block like restroom keys at a gas station. I think you have the right about the magnet as long as the screwdriver shaft is steel or something the magnet will grab. Good luck!
    May 2016
    Duncan, Ok
    89
    Got it out with a magnet. I think I'm going to tie something larger to it that floats. Got plenty of sticks I could use. Definitely a laughable learning experience.
    38,290
    It was 1 in a million Dr, 1 in a million
    Magnet should work fine.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Sand on that lid so it doesn't need tools to open. Problem solved.
    Mar 2015
    Sugar Land , TX
    424
    string with fishing hook might work, either way gives you something to do today LOL
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    May 2016
    Duncan, Ok
    89
    Going to go sand on the lid for a bit and see if I can get a better fit.
