Thread: How to pop out small section of liner bead
    Jun 2014
    Harrisburg, PA
    8
    I have a water bubble behind the liner along the water line and I want to pop off a couple feet of liner to test the water and see if it is caused by a leak or groundwater. However, I am having a hard time getting the liner out of track without damaging the liner. Any suggestions? I read somewhere to use a butter knife wedged in between the liner and track to pry it out, but I am not having any luck. My liner is only 1-1/2 years old, so it is still pliable and I can get some slack in it. Maybe my technique is just not right. Thanks for any help.
    Jun 2014
    Harrisburg, PA
    8
    Re: How to pop out small section of liner bead
    Never mind...used a piece of heavy gauge solid wire and bent the end to make a hook to help pull it out.
