Thread: Polaris 9450 vs. Aquabot Rapids 1500
    Jun 2016
    NJ
    4
    Just wondering if anyone has any experience with the polaris 9450. There are two things I've read about it that are starting to trouble me. The first is that the cord does not have swivel so having seen the problems with my aquabot turbo t2 and the cord tangling I don't want to go through that again. Secondly, I'm wondering how fine the cartridge may be. I've read reviews where users have said the it simply blows the debris out to have it picked up by the filter.
    My aquabot lasted 8 years so I'm hesitating on un-boxing the Polaris and considering purchasing the Aquabot rapids 1500.
    Does anyone have any experience with the Polaris?
    - dpd
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Re: Polaris 9450 vs. Aquabot Rapids 1500
    I had a Polaris 9300 that was junk the cable kept on tangling up (The cleaner it self did a great job but the cord was junk)
    there is no swivel on this design
    I ended up giving it away in buying a
    dolphin titan plus
    I would never recommend those cleaners
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Oct 2015
    austin/texas
    25
    I have a Polaris 9450. I think this unit is great! I have used it since opening the pool in April 2016. My cord does not tangle (much) and when it does it has not caused problems for the unit. The cord does not have a swivel, true, but that has not caused a problem with my unit.
    The Polaris 9450 cleans very well both floors and walls. It filters coarse and fine debris. It has never gotten hung up on objects in the pool such as drains.
    I am very happy with my 9450 and would consider one again!
    Jun 2016
    Lagrangeville NY
    24
    I was just about to post and ask for opinions myself.
    I've had the aquabot turbo T2, no problems noted, excellent cleaner, but it was finally time to replace it.
    Just got the Polaris 9450 from Amazon. Love the design and functionality. Very slick machine. Pretty good reviews. Couple of things I don't like.
    Doesn't seem to climb walls too well, especially once it has collected some debris in the collection bay. I think the impeller location being in the rear instead of on top maybe affecting this. Top impeller on the T2 seemed to add some downward force that may have helped keep it on the walls and floors.
    I HAVE seen it expelling dust or dirt out of the impeller port while its cleaning leading me to believe it's not filtering everything. As a result, the particles float and are either collected in the skimmer or settle back down after the bot is gone.
    I've noticed that the water leaving the impeller port creates a fair amount of turbulence behind it again kicking up dirt and debris for the skimmers to pick up.
    I think the design flaw is in the location of the impeller. Though I like everything else, I bought the bot so it would do a good job cleaning. I think I'm going to send it back this week.
    I'm looking at the Dolphin Triton on Amazon. Any opinions on that?
    Hope I've helped.
    Jun 2016
    Baltimore Maryland
    3
    After much research I'm between the dolphin premier and aquabot elite. I read lots about the Polaris spitting debri back into pool because of design. Also read about it stirring debri rather than sucking it up because of the way it uses water to propel.
    My pool is inground pool with pebble tech like finish. Pool size is 42x22 with an 8 foot tip out and 2 water falls. The pool starts at almost 4 ft and goes down to 9 1/2 ft. It's about 35,000 gallon with DE filter.
    May 2016
    New Jersey
    29
    I have the Polaris 9550 version which is basically the same as the 9450, except it has a remote and I can customize the cleaning cycle a little more. Replacing the general purpose canister with the Ultra fine sand and silt canister would solve the issue of the cleaner spitting dust or dirt out of the impeller. I have the fine sand and silt canister and I do not experience that issue. My unit also seems to climb the walls without any problems (I empty the canister after each cleaning cycle).
    I usually set the timer for 2 1/2 hours and the pool is spotless. I have a 20,000 gallon in ground vinyl liner pool.
