Thread: Vitamin cleaning question
    Hi,
    I read we can use vitamin C to clean the pool stain and rust. My question is could we use any other vitamin? Like vitamin D?
    - NY Albany ~27000 water
    - In ground Vinyl 18' X 40' X 8' Deep Curved Roman End
    - Pentiar TA 60 Sand Filter
    - Pentair WhisperFlo 1HP Energy Efficient Full-Rated 2-Speed
    - 250K BTU Nat/Elec. Heater
    38,305
    Re: Vitamin cleaning question
    No. What you need to use is ascorbic acid, vitamin c.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Usually we only suggest using Vitamin C tablets to test stains, for actual cleanup you likely need to do an ascorbic acid treatment of your pool water which typically requires a few pounds of ascorbic acid.
