Results 1 to 8 of 8
Thread: Chlorine levels and Dolphin Pool cleaners cleaners
    Jun 2015
    Central, NJ
    566
    Just bought a Dolphin Active 30i pool cleaner. I read the directions and it says do not use in chlorine levels higher than 4ppm. This means I can only have a CYA level of 30 and can not be used during a slam. I have not seen anything about this during my research before buying. Does anyone use them during slam and when Chlorine is higher than 4, such as when CYA level is above 30?
    27,000 gals (20 x 40), IG, vinyl, Hayward Sand Filter S244T 300LB, Hayward
    Super pump SP 2607X10 1 hp.
    38,251
    Re: Chlorine levels and Dolphin Pool cleaners cleaners
    Those suggestions ignore the buffering effect of the CYA. No worries following the TFP recommendations.
    Jun 2015
    Central, NJ
    566
    Ok even at slam levels?
    38,251
    At the recommended TFP shock FC level for a given CYA ... the active chlorine level (harshness of the water) is less than at a FC of 1ppm with a CYA of 0ppm (like many public pools).
    Jun 2015
    Central, NJ
    566
    That answered the question very well, thank you.
    38,251
    Here is the table if you are curious:
    http://troublefreepool.com/~richardfalk/pool/HOCl.htm
    Jun 2015
    Central, NJ
    566
    Thank you,
    I assume red means insufficient, green is good level, what does blue mean, too much?
    38,251
    Ignore the colors (I am not sure exactly what they are supposed to mean). Just compare the numbers.
