Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Hello everyone!
    ButcherBoy5375's Avatar
    May 2016
    Rialto California
    12
    Hello everyone!
    My name is Dan and im new to this forum as well as new to owning an above ground pool. On a recent trip to Costco for a couple small things , the wife and I noticed they had what looked to be a nice above ground pool for sale. It is a 16 x 9 x 48 Bestway brand pool that comes with a sand filter pump that has a flow rate of 2500 gallons per hour as well as all the accessories to care for the pool. After discovering this forum, we decided that we would like to have a saltwater system in this pool. I've done some reading here and there on this forum and I realized that the saltwater will rust the frame faster than usual. We are actually okay with that. After some discussion we decided that this will be a trial pool to decide if we really enjoy having a pool and enjoy maintaining it as well. So after three or four years we'll make a judgement decision and either buy a new larger pool or be done with it all together.
    So we bought the pool! Upon returning home with our new treasurer I quickly went to Amazon and found the Intex crystal clear salt water generator for pools up to 15,000 gallons with copper ionization for $108 and change so I purchase that. Intex Krystal Clear Saltwater System with Copper Ionization Amazon.com : Intex Krystal Clear Saltwater System with Copper Ionization : Swimming Pool Chlorine Alternatives : Patio, Lawn Garden
    Now fast-forward about a week or so, I've received my new salt water generator, I've leveled the ground with about four thousand pounds of sand, assemble the pool, filled it up, and it turned out to be level within a half an inch all the way around! That was no small task. from the literature that comes with the pool I know that my pool contains about 3,800 gallons of water. According to the literature with a saltwater generator, I've determined that amount of water requires between 80 and 90 pounds of salt. I've added about 90 pounds. So that's about where I am. I ran the pump overnight to dissolve the salt a little better and now I've come to a screeching halt. I have no clue what to do next to get this thing started. Are there any other chemicals I need before I can get this thing running? I have not turned on the saltwater generator yet. I have purchased a basic testing kit, but I have not opened it or used it. I bought this one from Home Depot.
    5-Way Pool and Spa Test Kit
    5-Way Pool and Spa Test Kit-62364 - The Home Depot
    Will that work for a saltwater pool? I noticed the saltwater generator came with some test strips but from what I read test strips can be quite unreliable.
    Anyways so that's where I'm at sorry about the long drawn out post but I really don't know where to start. If anyone can point me in the right direction I'd appreciate it and I look forward to following along and being a part of the community here on TFP!
    Bestway 16x9x48 steel frame pool aprox 3800 gal.
    Bestway flowclear sand filter pump 2500gph flow rate
    Intex Krystal clear swcg for pools ipto 15000 gal
    May 2015
    Land O Lakes, FL
    527
    Re: Hello everyone!
    To do this right, you will need a good test kit. One of the 2 kits on this site will work. TFTestKits. Taylor or TF-100.
    Right off the bat, you should be adding chlorine to get it up as the salt system may take too long to get it up to the right levels. You can use that test kit that you have to get started but it won't be enough. Use Pool Math link at the top to get the base chlorine (just straight bleach from the store) started and know how to adjust your PH.
    Would recommend that you get started reading Pool School and any thread like yours. You will see a pattern. Need to test, keep PH and Free Chlorine above the recommending levels.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hello everyone!
    Welcome to TFP
    We use poolmath to figure out all the math for us ^^^up there^^^
    That test kit will work for a seasonal pool but if you are really looking to get into "pooling" check out the link below for test kits, we love and use the TF100 as a great test kit..
    what you need,
    At walmart
    4 gallons of bleach/liquid chlorine for the pool isle 10% (names pool shock)
    1 4 pound HTH pool stabilizer 100% cyanuric acid (CYA)
    lowes
    20% Baume muriatic acid from the outdoor pool section, 2 gallon box
    put 1 pound CYA in a sock and float in pool until dissolved, you can knead it to dissolve it.. this gets your CYA to 40
    put 3 cups bleach in the pool to bring to 5 free chlorine
    now make sure pool is clear, nothing green, if good and clear
    add 1 more pound of CYA in the sock and dissolve
    turn on SWG
    keep Free Chlorine at 5, test every night at the same time, if below 5 run the pump and SWG longer if above run pump less..
    Check out pool school right below
    Let us know if you have any questions
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,048
    Re: Hello everyone!
    Welcome!
    Normally I;d direct you to some articles in Pool School and let you figure it out, but if that pool is full of water in this heat, you want to get it swimmable yesterday and not have it go green on you before the weekend is over.
    To that end... you need to do three things right away.
    One: Go grab the bleach from the laundry area. If it doesn't say scented or splashless or anything else but maybe 'concentrated', add 2 cups to the pool with the pump running.
    Two: break open that test kit and test pH, and Total Alkalinity. Post those results.
    Three: make a dash for Lowes or Home Depot and pick up some Stabilizer aka Cyanuric Acid and some Muriatic Acid and maybe another jug of bleach.
    By the time you get back, someone will have run poolmath for you to tell you how much of each of those to add.
    Then we can worry about educating you so you'll understand each thing we told you to do and can do it yourself in the future. There's lots to do initially, including disconnecting the copper bars in that SWG. But first, lets get the FC and pH right so people can get in and so it doesn't go green on you.
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    So im a little confused. Cowboycasey recommended I buy 4 gallons of bleach, while richard320 suggested i pour in 2 cups. Thats a huge difference. Is that just so i have an inventory on hand? Thanks again guys. I get off work in 30 minutes and ill be going directly to the stores to buy what i need.
    Richard320's Avatar
    Jan 2010
    19,048
    Re: Hello everyone!
    Quote Originally Posted by ButcherBoy5375 View Post
    Yes. SInce you have a SWG, you will only need a few days' supply of bleach, but it's good to have some standing by in the event of a big crowd or a SWG failure. I suspect he read too fast and didn't see the pool is only 3800 gallons.
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    The only muriatic acid they have at my local home depot is 14.5% hydrogen chloride. Will that do? It comes in a 2 gallon box.
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hello everyone!
    Sorry, that is a backup supply, I always keep 4 gallons around, you can do 2 gallons instead if you want... whenever your FC level drops and you need to bring FC up fast use the bleach instead of trying to run the SWG 24/7 to bring it up
    Richard320's Avatar
    Jan 2010
    19,048
    Re: Hello everyone!
    Yes, but adjust poolmath to that strength.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Hello everyone!
    Are you sure that pool is only 3800 gallons? Doesn't sound right to me.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    Quote Originally Posted by wjr75 View Post
    yes. acording to the manufactuer it is 3,913 gallons
    Welcome!
    ok so i used the test kit and ph was 7.6 and the TA was 20 from best i could tell. that one was a little tricky.
    Richard320's Avatar
    Jan 2010
    19,048
    Re: Hello everyone!
    7.6 pH is fine. Don't need acid yet. And that TA doesn't sound right. Typo, maybe? Or multiplication error?
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    Hey richard. I just realised you said to put the bleach in first before i tested. I did not. Those results are from just the plain water with the salt added. I poured 3 cups of bleach and ran the pump overnight. I'll go out and test right now. Sorry man. This is all very new to me and i appreciate your help and patience. Ill get it right.
    Richard320's Avatar
    Jan 2010
    19,048
    Re: Hello everyone!
    The small amount of bleach you added wouldn't have messed up the pH or TA results at all. No problem either way before or after bleach. I'd just expect TA to be more like 120 or 200 than 20.
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    wow! you are good sir! PH stayed the same and TA took 20 drops to go from purpleish to clear. i was not seeing any results after 2 or 3 drops so i stopped last night. but after seeing your expected results, i kept adding till i saw something. so 20 drops x 10 is 200 for TA right?
    Richard320's Avatar
    Jan 2010
    19,048
    Re: Hello everyone!
    I'm not sure. I've never used that brand of tester.
    Have you added the CYA via the sock yet? poolmath says 2.5 lbs which will be 5 measuring cups. And have you checked the FC today? People are going to want to use it, if they haven't already.
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    that pool math calculator made my head spin. that may have had something to do with the couple of beers i had last night. no cya yet. ill do that next. so thats 5 1cup portions?
    Richard320's Avatar
    Jan 2010
    19,048
    Re: Hello everyone!
    Yep. In a sock or nylon. Hang it in front of the return so it gets pummeled by the water flow. Something like this.
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    cool. working on it. i have a scale so ill measure by weight.
  20. Back To Top    #20
    May 2016
    Rialto California
    12
    Re: Hello everyone!
    Sorry Richard, had a family emergency and had to come out to longbeach. I did manage to get that sock in the water before we left though.
