Results 1 to 9 of 9
Thread: In floor cleaning system - low pressure/suction from main drain?
    Jun 2015
    Southborough, MA
    29
    I have an in floor cleaning system with 5 rotating jets. After a few weeks of brushing floor debris towards the main drain, I noticed the debris doesn't seem to dissipate. Having decided to check the main drain, I noticed little pressure/suction from the drain itself. I did notice there is debris caught in the drain itself (too large to get through the trap - not clogged though). I also turned off the valve from the skimmer so that the main drain was the only feed back to the filte. I noticed little change. Should I be able to sense some pressure/suction from the main drain or is this normal? I should mention that when I shut the valve for the skimmer, the flow from the main drain does seem fine.
    Sorry if this is obvious. This is our first season with the new pool.
    thanks in advance-
    16'x40' Viking Rectangular fiberglass pool (depth 3' 6" to 8' ; ~ 27,000 gallons); Hayward AquaRite salt system; Hayward cartridge filters and propane heaters
    Paramount Vantage In Floor Cleaning system with Buzztop Channel drain
    9' x 10' Viking Raised Spa with Spillover - (depth 3' 4")
    Feb 2015
    Chandler AZ
    938
    Re: In floor cleaning system - low pressure/suction from main drain?
    Do you know the brand name of the in floor system?
    How many main drains are in the bottom of the pool? Some systems use a dedicated drain for the in floor, others use the main drains plumbed to the filter system.
    If you're unsure of the system brand, maybe post a couple pictures of the associated equipment.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jun 2015
    Southborough, MA
    29
    I believe it's a Paramount system. There's one drain. Looks like this one:
    Vantage - Paramount Pool and Spas
    Feb 2015
    Chandler AZ
    938
    In that case, do you have the in deck leaf/debris canister? If so, is the debris bag clean?
    Gene
    Jun 2015
    Southborough, MA
    29
    Quote Originally Posted by proavia View Post
    I don't. I do have this drain :
    Buzztop - Paramount Pool and Spas
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    How are you determining that you don't have much pressure? I have a Paramount in-floor system. Due to the design of the floor drain, it does not appear to have very much suction even though it does. Also, due to the design of my leaf canister, even if it is full there it can still pass lots of water with minimal pressure drop.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Jun 2015
    Southborough, MA
    29
    Quote Originally Posted by JayBauman View Post
    Just by diving down and inspecting by hand. I'm not feeling any pull ( unlike the skimmer draw). It does appear the drain is designed with a couple of layers. I suspect it may just be the design? Given that there is flow entering the pump when turning off the skimmer valve, there is obviously draw. I thought it was curious that the floor debris wasn't diminishing after several weeks of brushing, etc. and I wasn't sensing any pressure at the drain.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by Lpaul626 View Post
    Where is the floor debris accumulating? Is it close to the drain, or in other areas? If the jets don't push the dirt to the drain, it will not find its way into your filter.
    Jun 2015
    Southborough, MA
    29
    Agreed- It seems to settle in the same areas (next to the drain is one area). But I'm continuously brushing it out within range of the floor jets and it doesn't seem to diminish. Just resettle without being picked up by the drain which which is why I decided to take a look at the drain.
