Thread: Tried to coach someone along at the store
    May 2015
    Mount Cheaha Alabama
    250
    I had to grab some CYA to adjust up after refilling from winter.
    There was woman in the aisle with bucket of Clorox 3" trichlor pucks - she looked a bit confused, then asked me if they were the same as the Walmart brand of pucks on adjacent shelf.
    I glanced at active ingredients and confirmed they are the same concentration for ~$10 less.
    She asked what I used after stating she throws a couple of these in a 33' ABG pool skimmer every week - nothing else
    I tried to explain that it raised CYA level constantly if all you use is pucks - she appeared more confused.
    Showed her where the bleach was and recommended she try some, and probably test her water. She thanked me for the help and moved on with the bucket of pucks
    Then I realized how people end up with CYA levels over 200
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Tried to coach someone along at the store
    Something about leading a horse to water...
    Many people don't want to deal with managing their pool either because they are lazy, think they are too busy or maybe are intimidated by trying to learn the "right way" how to do it. Most pool stores don't help those notions either. Can only help those who want to take control of their pools. Good of you to try though!
    Isolated Spa - 345 Gallons
